Reducing lumination on exposed elements of clip at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old January 18th, 2012, 03:59 AM   #1
Hi,
O.k. over exposed clips are obviously bad, but can anyone suggest ways of removing the distraction, that the exposed elements of a clip cause on the viewers eye.
I've messed around with lumination, but not seeing much change, so not sure if doing it right, or if this is the right approacht to take.
LifeScenes
www.lifescenes.com | www.lifescenes.com/blog
Joe Thompson is offline   Reply With Quote
Old May 17th, 2012, 02:15 PM   #2
Re: Reducing lumination on exposed elements of clip
I was once happy with a trick I tried, generally:
Copy the footage as a new layer, cc it so the overbright pixels are white and everything else is black, (levels effect, black point to 254 or so) then use that layer as a luma matte on another layer that is blurred to bleed surrounding colors into the overexposed portions of the image.
Andrew J Morin is offline   Reply With Quote
Old June 18th, 2012, 11:42 PM   #3
I dunno what software you have access to or how much time you're willing to spend on it, but this might help:
Making a quick matte with Roto Brush | Learn After Effects CS5 & CS5.5 | Adobe TV
Ammar Ijaz is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
