AE: Transitions - Changing direction at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old October 18th, 2011, 12:47 PM   #1
I applied the Transition - Movement preset Stretch - Horizontal which works great other than the fact that by default, it flys in from the left and I want to change it to the right.
The issue seems to be that there is an expression for Transform - Position - Expression: Position:
if (effect("Stretch Master Control (edge)")("...the other side") == true)
{[thisLayer.width, thisLayer.height/2]}
else
{[0, thisLayer.height/2]}
What can I put in there to tell it to come from the other side of the screen?
thank you.
I like cake.
Dustin Alcock is offline   Reply With Quote
Old October 18th, 2011, 04:40 PM   #2
Re: AE: Transitions - Changing direction
Hi Dustin. If you look at the Effects Control Panel, at the top there is a Stretch Master Control. Tick the box that says "...the other side".
Gregory Gesch is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
