doing this effect, how to at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old July 23rd, 2011, 02:00 PM   #1
wanted to see ways to do this effect. starts at 1:19 through 1:22
seems pretty simple. its the close up shot. i have after effects, premiere.
‪Britney Spears - Oops!...I Did It Again‬‏ - YouTube
Dave Morgan is offline   Reply With Quote
Old July 24th, 2011, 02:03 AM   #2
Re: doing this effect, how to
Do you mean the flames?
If so I would usually think of doing something like that in a 3D package like Cinema 4D using its particle systems but that's probably because I have it and have done this kind of thing with it in the past.
I think there are some 2D particle system apps around as well like Particular that might do a credible job
Red Giant - Products - Trapcode Particular 2.1
Haven't used it myself (see above!) but take a look at it - or google "2d particle systems"
Old July 26th, 2011, 01:54 AM   #3
Masking those vertical portions and layering them on top of the original footage with effects like glow, embossing or whatever. I'm sure there's some kind of blending involved as well.
The other option is to create a transparent layer with effects, using coding - this second method is easier on the system.
Sareesh Sudhakaran is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
