Does motion have a wiggler? at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old June 7th, 2011, 10:44 AM   #1
Im an after effects guy, but at work it is not installed so I use motion to make my graphics/endcaps/thirds... However, one thing I haven't figured out yet is how to get variability in my effects without going through the timeline and adding a ton of keyframes.
Does motion have a wiggler or some sort of tool for me to define variability to the glows and blurs that it comes with? Google gave me nothing unfortunately...
Justin Molush is offline   Reply With Quote
Old June 7th, 2011, 12:57 PM   #2
Re: Does motion have a wiggler?
- Select a Group or an element you want to apply a wriggle to
- In the Toolbar go to "Add Behaviour > Parameter > Wriggle"
- Go to the Inpector Pane to select the Wriggle and adjust it's settings
- Important to do first is to apply the wriggle to a certain paramter: at "Apply To" you can click the button "Go" and select a certain parameter to influence!
Hope this helps,
regards,
Erwin
Erwin van Dijck is offline   Reply With Quote
Old June 7th, 2011, 02:21 PM   #3
Yes! Perfect, thank you.
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
