Cumulative Exposure Effect at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old October 26th, 2010, 01:27 AM   #1
Hi everyone,
I have has a request to use an existing video and average the contents of preceding frames into the current frame to give a long exposure effect. I am not sure how many frames back we need to go so it would be great if this was variable. It sounds like a fairly achieable effect and I suspect there is something available in AE already to do it but I can't find it.
Any Hints?
Jim
Jim Nicholls is offline   Reply With Quote
Old October 26th, 2010, 07:21 PM   #2
Hi Jim. Have a look at the Echo effect (or Time Displacement might interest you as well).
Gregory Gesch is offline   Reply With Quote
Old October 30th, 2010, 09:45 PM   #3
Another possibility is to duplicate your layer several times, offset each layer by a single frame, and then set the transparency mode on each layer to Screen or Add. For a less intense effect, use less layers or turn off existing layers until you reach the desired look.
Past projects, recent projects, and more! http://www.youtube.com/user/chugach3dguy
Shawn McCalip is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
