Blue screen Keying Software for Windows / Adobe PreimierCS3 ? - Page 2 at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old December 7th, 2010, 02:33 AM   #16
Originally Posted by Silas Barker View Post
I cannot find CS3 used and I can't upgrade to the newer CS4 or CS5.
Would the older version of Adobe After Effects, 6.5 or 7, work well for keying or should i get a totally different stand alone product. I wish I could get Ultra but I do not see it on amazon or anywhere used.
The stock chroma key effects in AE 6.5 or 7 are adequate tools, and if you have the patience and know-how, you can make them work. I've had to use them in the past, and while they're a little more finicky and less refined than some of the other options mentioned here, they can get the job done.
I will also add that one of the cool things about pulling a chroma key in After Effects is that you can apply the chroma key effect to a layer multiple times. This is useful if the photographer didn't have a blue/green screen lit properly or if the first effect isn't keying out enough of what you need. In some cases, I would duplicate layers and create mattes in tandem with the chroma key effect to pull cleaner keys.
Past projects, recent projects, and more! http://www.youtube.com/user/chugach3dguy
Shawn McCalip is offline   Reply With Quote
Old May 2nd, 2011, 09:29 PM   #17
Re: Blue screen Keying Software for Windows / Adobe PreimierCS3 ?
I use keylight in AE. It works great.
Here is a tutorial a showing how to use it: Keylight Keying Tutorial .
Ray Boykin is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
