#16 |
>> denoising is on par with NEAT Video but free
Slightly OT, but which denoiser(s) do you recommend, Perrone? I presently use the VDub version of Neat Video but am always interested in alternatives.... |
#17 |
I typically use the MSU Denoiser. It's slow but extremely effective.
DVX100, PMW-EX1, Canon 550D, FigRig, Dell Octocore, Avid MC4/5, MB Looks, RedCineX, Matrox MX02 mini, GTech RAID, Edirol R-4, Senn. G2 Evo, Countryman, Moles and Lowels. |
#18 |
Wanted to update this thread a bit...
Since fooling around with the settings, I've now settled on a default of 3000 for the smoothness settings. I've experimented up to 5000 for things I wanted very steady, and I understand some folks have gone up to 15k and above. So experiment and see what works for you.
#19 |
Deshaker
I installed the Deshaker plugin then I imported an AVI, set my parameters, made two passes and saved as an AVI. But my finished video still has the white motion tracking dots all over it and the numbers reading out in the lower left of the screen.
What'd I do wrong? |
#20 | |
When you make the first pass through the video, make sure the filter is set to PASS 1. When it finishes that pass, you have to bring the video back to the beginning (just hit the rewind key at the bottom) and go back into the filter and change it to pass 2. Otherwise it just redoes Pass 1 again.
#21 | |
If I look at Virtualdub, in the B window, the original file says "This frame was not processed in pass 1. And nothing will play. Black screen There's also a yellow box in the right corner of the B window saying "No previous frame to match on". |
#22 |
You are definitely doing something wrong... The Second pass should show no white dots in the output screen. So when you click "OK" on pass 2, it should take you back to the filters menu. Does it say (pass 2) at the end of the line for the deshaker filter?
#23 | |
1280x720 (rgb32) (?) (24fps) Deshaker v2.4 (pass 1) 1280x730 (rgb32) (?) (24fps) Deshaker v2.4 (pass 2) Yes, the second one shows 730, not 720, I click OK and the dialog box disappears. Then I click the <0 and it plays out and the resulting file is a snow storm of motion dots. Red dots too. SAVE AS results in another snow storm. |
#24 | |
Wait a second. You have TWO filters there in that dialog box?? There should only be one.
#25 |
It shows the first pass and second pass.
I even tried reinstalling vdub. It does make a nice snowstorm, easier than using AE. |
#26 |
Put up a screen shot of the filter settings, and the little dialog when get when you click OK on the filter settings.
#27 |
Here's some grabs, hope the text isn't too small. Getting really good at the snow storm effect.
#28 |
You have two copies of the filter running. Delete one of them and your problems will go away.
#29 | |
Question: it's the >0 button that applies the deshaker filter? And you literally make two runs on the file, pass one and pass two? Then save as. Why isn't this working! |
#30 |
Brian, listen to me....
Open VDub Open your unstabilized video Add a SINGLE COPY OF THE DESHAKER FILTER (you have two of them loaded) Enter your setting for both pass 1 and pass two IN THE SINGLE COPY of the filter Click the big pass 1 button at the top, and do the >0 Rewind the video Open the filter and click on the pass 2 button. Click ok Click the >0 again Save the new AVI.... You are not seeing the results you want because you have two separate copies of the filter loaded and the top one is always doing Pass 1.
