After Effects Cinelook Question at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old June 1st, 2004, 07:52 AM   #1
I have After Effects 6.0 and I am clueless as of how to use it. I've seen people do stuff using cinelook or something that is used in After Effects. I can't find this anywhere in the help or menus in After Effects. I someone could walk me through this process that would be awesome. Thanks
Kyle Kauss is offline   Reply With Quote
Old June 1st, 2004, 07:58 AM   #2
Cinelook is a plugin for After Effects, not part of the program.
If you are trying to figure out how to use After Effects, you might want to check out the 75+ tutorials over at my website.
Cheers
Stephen Schleicher
www.mindspring.com/~schleicher
Stephen Schleicher
www.stephenschleicher.com
Stephen Schleicher is offline   Reply With Quote
Old June 1st, 2004, 09:59 AM   #3
I see, so it's a program in itself no wonder I can't find it.
Old June 1st, 2004, 10:06 AM   #4
Wow only $700.00 bucks for it on there website
by the way your website is awesome I gotta go get some plugins and try out some of the stuff in your tutorials thanks
Old June 2nd, 2004, 07:39 AM   #5
Okay I got the Demo to try out how do I use it (I'm serious I have no idea how to even open it {it being cinelook}) in After Effects I loaded the plugins to my plug in folder in the after effects folder can anyone tell me how to open the program up and work it??
Old June 2nd, 2004, 10:32 AM   #6
you need to apply the effect (cinelook) to a video layer in your Timeline.
The manual goes into great detail on how to apply effects to layers. Also, if I am not mistaken, there is a pretty good manual for cinelook that you can download from the DigiEffects website that tells you what all of the Cinelook controls do.
Cheers
Stephen Schleicher
Old June 2nd, 2004, 11:48 AM   #7
Thanks again man, and I bookmarked your website there a lot of things you have on there that I need to learn thanks for all the help.
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
