Question for after effect gurus. at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old June 14th, 2009, 01:31 AM   #1
I shot a footage upside down, now when i'm changing the work space to tracking motion it doesn't let me rotate the footage? is it custom or i'm doing something wrong..??
Thanks! waiting for reply so as my projects :)
Arthur Abramov is offline   Reply With Quote
Old June 14th, 2009, 06:31 AM   #2
Try transforming the footage as soon as you bring it into the comp, before you do anything with tracking.
Reel Impressions Media - Make it more than a memory
GY-HD100- 7D- PSC Promix 3- Lectro/Sennheiser- Zoom H4- MPB- CS6/CC
Christopher Glavan is offline   Reply With Quote
Old June 14th, 2009, 08:27 AM   #3
oops... wrong thread...
Old June 15th, 2009, 04:34 AM   #4
Thank you Guys but it doesn't do
I tried to flip the original clip 180 degrees but when i open the tracking panel and actually elect that specific slip to track, it automatically clean it our any adjustment i did to the clip. Its amazing,
how can i go around it? do i really need to export the clip out flipped then reimport it back again ready to track , i'm working as a dynamic link with premiere it will disturb the whole project.
Old June 15th, 2009, 11:10 AM   #5
pre-compose the footage layer, and track that composition's layer, not the footage. The tracker works with the layer in the active composition before effects are applied...pre-composing forces AE to use the effects applied in that other composition. You may also choose to adjust the contrast and such in the pre-comp to improve the tracker's accuracy.
Andrew J Morin is offline   Reply With Quote
Old June 20th, 2009, 04:52 AM   #6
This is great thats Andrew. Thank you all guys
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
