Adjusting video clip speed? at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old May 13th, 2009, 02:48 AM   #1
For the life of me I cannot figure out how to simply change the velocity of video clips in AE! Can someone point me in the right direction? Much obliged!
Robb Swiatek is offline   Reply With Quote
Old May 13th, 2009, 05:11 PM   #2
Changing Speed
Select your video layer. Go up into Layer, then click on Time and select enable time remapping. It puts a keyframe at the beginning and end of your clip. You can then adjust those keyframes, play around with the graph etc!! Its pretty nifty!!!
Nick @ ProJuice
Pro Juice - Music Video Multimedia
music - video - multimedia
Nick Calpakdjian is offline   Reply With Quote
Old May 13th, 2009, 08:18 PM   #3
I think I even knew that at one point! Anyways, thanks Nick!
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
