Keylight blocky render nightmare at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old September 24th, 2008, 01:12 AM   #1
Hey all,
I have looked everywhere to this solution!!!
When I apply Keylight in After effects it crops the image in quarters and flickers the keyed background at random times.... Its doesn't matter what it is rendered out as and shows up in Ram preview as well. arrrgghhh!
This is extremely frustrating especially when they release a professional keyer then don't supply any support for this problem, which allot of people have..
Does anyone have any solutions to this Keylight bug.
Im running
32 bit Vista
intel 6700 dual
3gb ram
8600Gt
cheers
Blake Raidal is offline   Reply With Quote
Old September 24th, 2008, 10:09 AM   #2
Blake,
Keylight doesnt deliver for me. I'm using greenscreen all the time and the plug in that delivers clean keys for me is Primatte from redgiant.
It has a feature that removes blockiness from HDV footage.
A lot of other features too many to mention.
Red Giant Software: Visual Effects Plugins for Digital Video
Ted
Old September 24th, 2008, 09:35 PM   #3
thanks for the tip, I downloaded the trial and had a play. Its very simple to get solid keys, I'll have to put it on the workstation wish list though. I can't see my boss splashing out $600 for a keyer at the moment.
Old September 25th, 2008, 08:43 AM   #4
When Keylight flakes on me, I've worked around it by setting the output mode to "Matte Only" and then using that as a track matte on a second copy of the footage layer. My theory is that these problems stem from the color-correction end of things, which gets bypassed with the above trick.
Slightly simpler is setting the output to 'intermediate result,' so you may want to try that as well.
Both tricks require further key-processing, but you get the 'good' part of keylight and then have the freedom to tinker further with the key.
Andrew J Morin is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
