updating Photoshop layers in AE7 at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old May 20th, 2008, 10:29 PM   #1
I have a simple comp animating multiple layers and a camera in AE7. All the layers derive from a Photoshop CS2 file.
If I edit the layers in CS2 and save it, is there a refresh button or something I can hit in AE7 to get it to recognize the new edits?
Scott
Shot-By-Scott
Scott Brickert is offline   Reply With Quote
Old May 22nd, 2008, 02:53 AM   #2
Yeah, just right clicking on the file in the project bin/panel and selecting 'reload footage' does the trick I think. Not sure if you have to do it each time for the individual layers though
Murray Christian is offline   Reply With Quote
Old May 22nd, 2008, 08:32 AM   #3
I think it might be a little different with a Comp. In my case the layer names change, from merging or whatever, and reload doesn't work. You have to go into the folder in your project window, which has all the layers of the .psd comp file. Then reload (or even replace) the layer there.
Aric Mannion is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
