Speeding up a project clip in AE at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old May 15th, 2008, 04:07 PM   #1
So I have this template with which I'm working, and it's a 3 minute project.
I want to cut it down to 30 seconds.
What's the best way to speed it up, yet retain all of the timing of all the components in the Comp?
Craig Lieberman is offline   Reply With Quote
Old May 15th, 2008, 06:40 PM   #2
time remap
~Mechis
Marcus Lee is offline   Reply With Quote
Old May 16th, 2008, 10:52 AM   #3
You can nest the comp (just drag it into a new comp) and "time stretch", there you can type in the length you want.
I had problems with this when doing a complex animation, where I could tell the things were a frame or half a frame out of sync -so things dissapeared for 1 frame on a cut. In this case I rendered an animation, and sped that up instead of the comp.
Aric Mannion is offline   Reply With Quote
Old May 16th, 2008, 09:45 PM   #4
Thank you, the nesting seems the most logical solution. Thank you, all contributors.
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
