Weird After Effects problem at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old March 21st, 2008, 11:10 PM   #1
I'm learning AE (CS3) and I'm having a strange problem where all of the AE windows periodically shift down and right about a quarter of an inch for about a second and then return to their normal position. If I'm accessing a menu at the time of the shift everything gets garbeled.
My system is pretty high end (Dual Zeon, 4 gigs ram and an EVGA 8800GTS graphics card.) This seems like a graphics card problem. I'm using the latest drivers. Has anything had this problem? Any ideas?
Thanks, Marc
Marc Salvatore is offline   Reply With Quote
Old March 24th, 2008, 08:56 AM   #2
hope you get an answer, I get a similar issue with illustrator, although AE is perfectly ok.
I would have a search, and update your graphics drivers to the latest versions?
Chris Coulson is offline   Reply With Quote
Old March 24th, 2008, 01:13 PM   #3
Thanks Chris.
No answer yet and I am running the latest drivers. My next step will be to reinstall everything and then try using another graphics card.
Regards, Marc
Old March 25th, 2008, 10:46 PM   #4
You could try turning off adaptive resolution. This might help, but no promises.
Frank Hardie is offline   Reply With Quote
Old March 26th, 2008, 12:03 AM   #5
Thanks, tried it but did not help.
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
