curved edges at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
After Effects, Shake and everything else.
Old August 15th, 2007, 11:59 AM   #1
curved edges
Afternoon,
I'm doing a multi channel video piece for someone and I wanted to have the edges of the video curved instead of at right angles. I've been tinkering around in FCP6 and Motion 3 but haven't found a suitable way to do it. Any suggestions?
Nate Benson is offline   Reply With Quote
Old August 15th, 2007, 04:47 PM   #2
Do you mean something like the image I attached?
I just created this in Fireworks. It can also be created in Photoshop. I can create different ones if you want something different.
What is the pixel size of your project?
Are you looking for more rounded corners, or even a circle or oval in the middle of the screen?
Kevin | www.kraentertainment.com
A picture is worth 1,000 words | A 2 hour film at 24fps is worth 172,800,000 words
Kevin Amundson is offline   Reply With Quote
Old August 15th, 2007, 05:11 PM   #3
Why not use the Vignette filter? I have it in FCP5, I'd imagine its still in 6, but unsure.
There should be a list of filters in your manual, check it for Vignette
Lisa Shofner is offline   Reply With Quote
Old August 15th, 2007, 07:58 PM   #4
Or is this what you wanted?
Old August 16th, 2007, 10:07 AM   #5
Yeah, that's something I'm looking for. Can I use that as an overlay?
Old August 16th, 2007, 05:37 PM   #6
Yes, the file is a .png with alpha.
Is this the correct size, or do you need the corners cropped in more/less?
Also what pixels size do you need?
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Digital Compositing and Effects
