Dn60 at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Datavideo DN-xx Series Recorders
Formerly known as nNovia QuickCapture QC A2D2 other nNovia products.
Old August 29th, 2013, 03:32 PM   #1
Dn60
I have had the DN60 for a few weeks now and all has been fine until tonight its all connected correctly but in record mode its flashing bad input I have tried another firewire cable but its just the same, its been working fine any ideas please
Ian Thomas.
Thomas Video Productions
Ian Thomas is offline   Reply With Quote
Old August 30th, 2013, 02:24 PM   #2
Re: Dn60
all sorted
Ian Thomas.
Old August 31st, 2013, 06:28 AM   #3
Re: Dn60
Hello Ian.
I've recently started using DN-60s on my cameras. It's good you got the issue resolved. Would you mind elaborating a little in case anyone else runs into your issue?
Roger
My YouTube Channel: https://www.youtube.com/channel/UCAp...2AHr_pHFID5LDA
Roger Van Duyn is offline   Reply With Quote
Old August 31st, 2013, 09:27 AM   #4
Re: Dn60
To make the DN60 work correctly you MUST follow the steps starting up and shutting down. Any deviation and the DN60 will not record. You also need to use the shortest possible FireWire cable.
Greg Clark is offline   Reply With Quote
Old September 1st, 2013, 03:23 PM   #5
Re: Dn60
Roger
the camera Iam using the internal battery was low so when I changed battery the camera went back to factory set so iLink was set wrong changed it and away we went again
Ian Thomas.
Old September 2nd, 2013, 12:18 PM   #6
Re: Dn60
Thanks for the info Ian.
Roger
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Datavideo DN-xx Series Recorders
