How good is the DN-60? at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Datavideo DN-xx Series Recorders
Formerly known as nNovia QuickCapture QC A2D2 other nNovia products.
Old October 8th, 2010, 04:47 PM   #1
It would be nice to hear more positive or negative comments before deciding to purchase this add on for my Canon XH-A1 and Windows 7 Premiere Pro CS5 editing system.
Greg Clark is offline   Reply With Quote
Old October 14th, 2010, 11:21 AM   #2
Greg, i use the EXACT same setup; XH A1, DN-60, Win7 64 bit, CS5.
Works flawlessly; i no longer have any HDV tapes, just a few CF cards. Feel free to ask any questions and ill answer them best as i can.
Panagiotis Raris is offline   Reply With Quote
Old October 19th, 2010, 10:05 PM   #3
Panagiotis, if you had to swap out a cf card and continue rolling, how long before the DN 60 lets you pull the card to swap it out? How long does it take to swap out a card and start recording?
Paul Pelalas is offline   Reply With Quote
Old October 20th, 2010, 06:27 AM   #4
More questions for Panagiotis
Can you replace tape on the XH-A1 and keep recording the CF card on the DN-60 at the same time?
Have you experimented with how long the 4 AA's will last?
Can you use any CF reader to dump the video into your computer?
What is the maximum size of CF card that the DN-60 will accept?
How do you deal with poorly lit screen on the DN-60 while recording in low light areas?
Thanks for offering to help.
Old October 20th, 2010, 06:39 AM   #5
i have th dn60 , i bought it on the very first day of it release.
works ok.. have some errors but generally am very satesfied from this tool
when am filming events like weddings I prefer to shoot on tape and on cf at the same time....
i use a transend 64gb compact flash card and i have 4,5 hours of video.
the main problem that i found some times is that on few clips the audio is not sycronized with the video..
I use the dn60 with a canon xha1, premiere cs4 and win7 64bit
Anthony Mozora is offline   Reply With Quote
Old October 20th, 2010, 08:27 AM   #6
Anthony, what is the speed of the Transcend card your using? I didn't see the Transcend cards on the list of cards they suggest you use in the DN 60 . Maybe that's why you have some errors or audio sync problems?
What kind of errors are you having.
Old October 21st, 2010, 10:32 AM   #7
my transcend card have this specs
Ultra-fast 400X performance with four-channel support
Manufactured with brand-name MLC NAND Flash chips
Conforms to CF Type I standards
Data transfer rate: Read-90MB/sec (Max) / Write-60MB/sec (Max)
I wanted to buy a SanDisk Extreme Pro 64GB (90MB/s BUT is way to expensive .
Anyway , generally i dont have errors all the time.
only some times. when the clip is very long i have the error of not sychro with video..
how do i handle the above issue ^^^ i capture the video from the dn60 to the pc with firewire, like i do with tapes. and vouala! the audio is sychronized with the video on all the clips! strange but true! :)
sometimes my pc just can not edit few clips from the datavideo bin. they play with any player but i just can not edit them with any editing software that i have. the pc is freezing and the program stop working..
Old October 27th, 2010, 11:56 AM   #8
fast as you can; you stop recording, eject the old card, pop in the new card (assuming you have preformatted it for whatever you are about to use it for, otherwise it takes about 1 minute to format a 16GB card) and hit record again.
i preformat all the cards for the same HDV NTFS file system, so i just swap and go. later, i have to hit 'make media files' on each card and then get the files off the memory cards on my PC.
Transcend and Kingston cards i have found to be problematic; i use SanDisk Extreme III 30MB/sec cards; never had a problem. Transcend and Kingstons (and all the cheaper brands too) ive had dropped or green frames.
Old October 27th, 2010, 11:59 AM   #9
yes you can replace an HDV tape and still be recording to CF card (have to disable sync to tape). this is how i would shoot really long events; tape and CF when tape is about to run out. theoretically as long as you have juice and spare HDV tapes you could keep shooting indefinately.
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Datavideo DN-xx Series Recorders
