Set Global Output Mode in obsolete Version...
Hello,
after updating Stereo3D Toolbox LE I donīt have the option to "Set As Global Output Mode" or choose the output Mode in the new version. In the onscreen-menu I can deselect "Use Global Output Mode", then choose a different output and click the "Set Now" button - but it doesnīt have any effect on other clips, although they have the "Use Global Output Mode" box checked. If I use the old one (it says obsolete...) it is still there and works - should I use that or is there anything I miss? Thanks, Claudius |
Re: Set Global Output Mode in obsolete Version...
Hi Claudius
Is it possible your other clips have already rendered (don't have a orange bar above the clips?) We recommend turning off background rendering when working with the global mode workflow so you can render when you are ready.
Tim Dashwood |
