Apollo files and Edius 8 at DVinfo.net
Convergent Design Odyssey
Old November 10th, 2017, 03:00 AM   #1
Hi after many years of faithful service my by my Nanoflash it's to move on. My question is that I am looking at buying the Apollo unit as I need a small portable switching unit for very confined areas. The unknown element is that I edit with Edius 8 and I am not sure of file compatibility with the multi stream file produced by the Apollo.
I would appreciate any advise on this matter.
Many Thanks
Lance Librandi is offline   Reply With Quote
Old November 10th, 2017, 07:58 AM   #2
Re: Apollo files and Edius 8
If you use Edius, you are probably aware of the Edius forums. If you post that question in the "editing" section, I bet you will get an answer. Works for me.
Good luck.
Dan Gunn is offline   Reply
