SDI 4K output at DVinfo.net
Convergent Design Odyssey
Old January 23rd, 2016, 07:02 AM   #1
SDI 4K output
Will the 7 Q sdi output ever be 4K rather than HD. Thank you
Bill LiPera is offline   Reply With Quote
Old January 23rd, 2016, 07:13 AM   #2
Re: SDI 4K output
No it won't, unless it can work with both SDI A and B out in tandem over 3G. Where would that go into though?
Old January 23rd, 2016, 09:12 AM   #3
Re: SDI 4K output
How about HDMI output. Will that ever be 4K. Thanks
Old January 23rd, 2016, 10:27 AM   #4
Re: SDI 4K output
Dear Bill,
With the Odyssey7Q/Odyssey7Q+, the HDMI output is not capable of 4K.
However, we have 6 HD-SDI ports on the Odyssey7Q/Odyssey7Q+:
Two Dedicated Inputs
Two Bi-Directional (can be either an input or an output) based on firmware control.
Two Dedicated Outputs
Thus, if we can accept the 4K input via two ports, we would have four HD-SDI's available for 4K output.
If we accept the 4K Input via four ports, then we would have two HD-SDI's available for 4K output.
4K @ 30 fps, in 2SI mode uses HD-SDI 3G Dual Link, thus this mode uses just two ports.
4K @ 60 fps, in 2SI mode uses HD-SDI 3G Quad Link, thus it needs four ports.
Bill, please feel free to call me:
seven one nine --- nine three zero ---- one three seven six (I am in the US.)
Respectfully,
Dan Keaton
Augusta Georgia
Dan Keaton is offline   Reply
