Odyssey 7Q Audio and Blackmagic Media Express at DVinfo.net
Convergent Design Odyssey
Old December 2nd, 2015, 11:43 AM   #1
Blackmagic Media express plays Odyssey 7Q 4K prores 422 footage beautifully but there's no audio. It appears that 7Q 4 Kprores video 422 records 32 bit audio. If I convert the footage to 4K prores 422 with 24 bit audio then the sound plays well. Is there any way to record 24bit audio with the Odyssey 7Q so that the conversion and the recompression can be skipped. Thank you.
Bill LiPera is offline   Reply With Quote
Old December 7th, 2015, 11:36 AM   #2
Re: Odyssey 7Q Audio and Blackmagic Media Express
Dear Bill,
I am alerting our team about this.
We will attempt to duplicate this in our lab.
I will provide more information after I discuss this with our team.
Respectfully,
Dan Keaton
Augusta Georgia
Old December 7th, 2015, 01:34 PM   #3
Dear Bill,
I received word back from our Lab Manager.
"This is most likely a setting with Media Express, as we use this for testing with Apple Certification"
Are you using a Mac or a PC?
Respectfully,
Dan Keaton
Augusta Georgia
Old December 7th, 2015, 05:02 PM   #4
Thanks for the response I'm using a pc . I can't seem to find that setting in Media Express. Thank you
Old December 8th, 2015, 07:29 AM   #5
Sponsor: Westside AV
On Macs the settings are in System Prefs/Desktop Video. There are many audio/video settings there, depending on your hardware.
Old August 29th, 2016, 02:43 AM   #6
Just bumping this thread, can someone give me the output of a "ffmpeg -i (input file).mov" of a file like this? and can this be remedied with a simple command like this?
Code:
ffmpeg -i "(input file).mov" -c:v copy -c:a pcm_s24le "(output file).mov"
Old August 29th, 2016, 04:39 AM   #7
Dear Jack,
I am sorry, but I do not have an answer for you.
I will check with our team.
Respectfully,
Dan Keaton
Augusta Georgia
Old October 31st, 2016, 07:31 PM   #8
Hey Bill,
I just tried out converting the audio using an FFmpeg command and I can tell you it works in Media Express on machines with Quicktime installed. (Protip: Media Express will not read ProRes files on Windows unless Quicktime is installed. You can use the "for NLEs" installation method and not install the player.)
Here's the command you have to enter in ffmpeg:
Code:
ffmpeg -guess_layout_max 0 -i "(path to input file, ending in .mov)" -r (Frame rate from the clip's XML file in the same folder as your source clips. Round up non-drop frame rates to whole numbers, AKA don't include decimal points.) -c:v copy -c:a pcm_s24le "(path to output file, ending in .mov)"
Hope this helps.
Jack Zhang is offline   Reply
