New Odyssey firmware update 2015.5 at DVinfo.net
Convergent Design Odyssey
Old June 3rd, 2015, 11:42 AM   #1
Sponsor: Convergent Design
Please note new naming convention for firmware updates, containing year followed by month.
NEW FEATURES (ODYSSEY7 / ODYSSEY7Q / ODYSSEY7Q+)
• Expanded Odyssey LUT System, including custom 3D-LUTs
Improved & Expanded set of Preset LUTs
Support for user-loadable custom 3D-LUTs (up to 140, Odyssey7Q, Odyssey7Q+)
17x, 32x, 33x, 64x, 65x 3D-LUT (.CUBE format) Supported
.CUBE Luts translated for Odyssey using CD 3D-LUT Converter App
LUTs are currently for MONITORING only, not “baked in”
LUTs viewed during recording noted in XML file metadata
(new CD Apple ProRes Transfer Utility 1.7 required)
Extended and Legal Range LUTs Supported (EE vs LL)
• LUT Routing to Tools & Outputs
Image Analysis Tools can measure “LUTTED” image or original source
Video outputs can independently turn ON/OFF LUT or Mirror OLED
• Anamorphic Desqueeze
2.0x, 1.5x, 1.33x Support
Corrected image sent to video outputs, recording unaffected
• 4K / 2K Monitoring Modes (Odyssey7Q, Odyssey7Q+)
17:9 Letterboxed within 16:9 image or Center-Cut to 16:9
Letterbox or Center-Cut image sent to video outputs, full frame recorded.
• Monochrome Monitoring Mode
View Luma only or individual Red, Green, or Blue channel in grey tone
• Dual Zebras
Set high & low for each, can overlap, separately selectable colors
• Expanded False Color Mode
Added Pink for Six colors
Each color set high & low, can overlap
• Expanded OLED Controls
Advanced Monitor Calibration Controls
Color channel bias controls, SMPTE color bars reference
• Improved Multi-Stream Mode Switching
Switch between inputs without image flicker or glitch.
• Safe Eject at power down
Automatically closes all file directories on shut down
• Improved Sony FS RAW color reproduction
Improved image quality in CinemaDNG and Apple ProRes recording
FS700 Apple ProRes recording with S-Log2 or REC709(800%)
FS7 CinemaDNG & Apple ProRes require SGamut3.Cine Color Space
FIXES & IMPROVEMENTS
• FIXED AUD OUT (Headphones) unmute
• FIXED Audio gain settings when switching Analog to SDI
• FIXED Safe Eject process to remove OLED flashing during procedure
• FIXED FS700 4K RAW -> HD Apple ProRes detection
• FIXED HDMI Legalize Input setting
• IMPROVED 4K Apple ProRes playback
• IMPROVED 4K pixel zoom 1:1 and 2:1
• IMPROVED PSF output support in all modes
• IMPROVED Reduced overall power usage
• IMPROVED Interlaced playback support
• IMPROVED 4K -> HD Apple ProRes playback
SOFTWARE UPDATES
• CD Apple ProRes Transfer Utility 1.7
- Pomfort LiveGrade support for Odyssey LUTs
Mitch Gross is offline   Reply With Quote
Old June 3rd, 2015, 11:45 AM   #2
Re: New Odyssey firmware update 2015.5
Please visit our website to download the new firmware and to find lots more information, including documentation on the new Odyssey LUT System, downloadable 3D-LUTs, instructional videos, 3rd party support info and more. If you can't find the info, everything is in our blog.
https://convergent-design.com/company/blog-news.html
Old June 3rd, 2015, 12:37 PM   #3
Love the new additions in this latest update( 2015.5) but NOTICE that 3rd party SSD's were not supported.
"Access to the use of these two Samsung 850 EVO SSDs is expected to be made available with the May 2015 free Odyssey firmware update. Only the Samsung 850 EVO 500GB and EVO 1000GB SSDs, along with the Odyssey 256GB, 512GB, and 1TB SSDs, will function in the Odyssey monitor/recorders."
Wondering if you this is still on the Roadmap Update for release SOON?
Brian Hoodenpyle is offline   Reply
