GH4 HD Settings Issue w/ 7Q+ at DVinfo.net
Convergent Design Odyssey
Old May 4th, 2015, 09:50 AM   #1
I've run into an issue, where the contrast, saturation, etc settings are either not being sent, via HDMI, or not being recorded by the 7Q+. This only occurs when the camera is outputting an HD signal. The settings come across fine in 4K. Anyone else run across this and find a solution?
Kenn Christenson is offline   Reply With Quote
Old May 4th, 2015, 12:19 PM   #2
Re: GH4 HD Settings Issue w/ 7Q+
So... to answer my own question: This looks like a glitch in the camera, that can occur when switching form 8Bit to 10 Bit or 4K to HD. The solution seems to be to turn the camera off and back on, again - when you observe the camera setting are not functioning.
