SSD/Footage inaccessible / corrupted? at DVinfo.net
Convergent Design Odyssey
Old January 28th, 2015, 07:24 AM   #1
Hi,
Could not find any similar issues in the forum.
Been filming on a project for two days with the 7Q+ and 2 x 512 SSD.
Been shooting in UHD/4K ProRes (Sony).
Unloaded some files from the SSD from one day, no problem.
Now when I get back home I am having issues accessing and unloading the files from the second day of shooting from the SSD. Only one of the SSD has been used.
I can play the files back on the O7Q+, but neither a windows computer or Mac is able to copy the files.
The Mac wont even recognize the drive, the WinPC occasionally suggest the SSD need to be formatted to be accessed. I have 3 different SSD readers (USB 3.0) and all of them have preciously worked for offloading the files, none work now. :(
But when I get the WinPC to recognize the SSD I am unable to copy the files, Windows explorer just hangs.
I cannot play the files in windows from the SSD either
Should I hit "rebuild" on the Odyssey?
What do I do?? These are really hard to get shots, I cannot afford to loose them.
Ole
Ole Salomonsen is offline   Reply With Quote
Old January 28th, 2015, 07:40 AM   #2
Re: SSD/Footage inaccessible / corrupted?
Dear Ole,
The Rebuild process (named Rebuild starting with firmware 4.10.100, previously it was called Recover), in the Odyssey|SSD menu, is a completely non-destructive process.
I recommend that you perform the "Rebuild".
As you may know, we provide 24/7 support. You may reach me at:
seven one nine -- nine three zero -- one three seven six.
During normal business hours, you may reach our main support line, in Colorado Springs, Colorado, USA, Mountain time, at
seven two zero -- two two one -- three eight six one
Respectfully,
Dan Keaton
Augusta Georgia
Old January 28th, 2015, 09:02 AM   #3
Dear Dan,
thank you for your swift reply.
Rebuilding / recover done, saved all files, all good.
BTW! Getting a message that "SSD ejected without safe eject" after ejecting after rebuild.
But I a cannot hit safe eject on the screen after rebuild, so I guess the safe eject is already done within the process. So that error message is a bit misleading and scary then.
Thank you
Reg,
Ole
Old January 31st, 2015, 06:50 PM   #4
Dear Ole,
Yes, I agree.
We can correct that in our firmware.
The Rebuild/Recovery process automatically performs a safe eject, so that other message is wrong.
Respectfully,
Dan Keaton
Augusta Georgia
Dan Keaton is offline   Reply
