Movcam Odyssey 7Q Power Bracket Now Available at DVinfo.net
Convergent Design Odyssey
Old August 6th, 2014, 01:19 PM   #1
Austinite
Power Your Monitor Cage
The new Movcam Power Bracket was designed to work seamlessly with your Odyssey 7/7Q monitor. Power multiple accessories using the various voltage connectors or add Movcam Anti-skid Handgrips for a custom handheld option. Available now, the Movcam Power Bracket for the Odyssey 7/7Q is built with outputs for one 5 volt, one 8.4 volt, one 14.4 volt and two 12 volt connections.
https://www.flickr.com/photos/omegab...t/14846167055/
Phil Goetz is offline   Reply With Quote
Old December 26th, 2014, 09:50 AM   #2
Austinite
Re: Movcam Odyssey 7Q Power Bracket Now Available
And it works with the 7Q+ because it is the same physical form factor...
