Mixed file recording ? at DVinfo.net
Convergent Design Odyssey
Old May 13th, 2014, 10:04 AM   #1
Hi guys
So I'm up and testing with the rig.
I know the firmware release says
Mix file types on SSDs (raided, non-raided, RAW, ProRes, etc.)
Now does that mean that it would be ok to shoot a bunch of 4k raw shots then switch to 4k>2k Prores and carry on recording on the same formated drive.
I'm guessing shooting 240frms RAW/raid format should be shot on its own pair of drives ?
Mat
Old May 13th, 2014, 10:39 AM   #2
Re: Mixed file recording ?
"Now does that mean that it would be ok to shoot a bunch of 4k raw shots then switch to 4k>2k Prores and carry on recording on the same formated drive.
I'm guessing shooting 240frms RAW/raid format should be shot on its own pair of drives ?"
Mix and match all you want with the latest firmware (1.11.100). 240 fps requires 2 drives but you can also mix and match that with video that only requires one drive.
John Mastrogiacomo is offline   Reply With Quote
Old May 14th, 2014, 10:14 AM   #3
Thanks John
That's good to know.
mat
Mat Thompson is offline   Reply
