Nanoflash & AF100 settings for 23.98p at DVinfo.net
Convergent Design Odyssey
Old January 21st, 2014, 07:11 PM   #1
I'm trying to get my head around a workflow question, hoping someone (Dan?) can confirm settings.
Read thru manual, think I have this correct but would love to hear from experienced Nano users....
Shooting 1080/24p (23.98) w. AF100, I shoot this way often, edit in FCP 7, no problem w. AVCHD files ( converted to ProRes), footage and project / sequence all at 23.98.
Just got a Nanoflash. Feeding it via SDI from AF100.
Question - If I want to end up editing 23.98 FCP sequence (same as AVCHD workflow) - what should following settings be?
1. on AF100 - SDI OUT PsF - ON or OFF? I'm guessing ON...
2. on Nanoflash - Record PsF Prog - CHECK or UNCHECK?
3. Play Prog PsF - CHECK or UNCHECK?
4. Remove 3:2 pulldown - CHECK or UNCHECK. I'm guessing UNCHECK because AF100 PsF does not add pulldown, as I understand it. Correct?
Many thanks for a reply.
Darryl Czuchra is offline   Reply
