Delkin Card Failure at DVinfo.net
Convergent Design Odyssey
Old November 18th, 2013, 05:24 PM   #1
Delkin Card Failure
Hi I have a Delkin UDMA 64gb card that's is just over 2 years old and it will no longer format or play the contents on the Nanoflash rev 1.6.248.
When the card is inserted into the Nanoflash I get "DMA RD(1): Err=0004" message.
If I try to format the card the format process goes ahead but seems to hang and at then I get
"Insert (1): 97,0004 message.
Any insight would be appericated.
Lance
Lance Librandi is offline   Reply With Quote
Old November 18th, 2013, 05:39 PM   #2
Re: Delkin Card Failure
Have you tried to read it with your computer?
Look in the slot of the recorder and make sure one of the pins isn't bent.
http://www.LandYachtMedia.com
Old November 18th, 2013, 08:04 PM   #3
I can read and transfer the contents. I also out of desperation attempted to format the card in fat32 but windows 7 report I/O error and nothing happens. I also tried to clean, partition and format the card from the CMD without success.
l have never seen this with a card where you can still read the contents of the card but not format the card, almost like it's been write inhibited.
I wonder if it's a control chip problem on the card that's failed.
Old November 18th, 2013, 09:33 PM   #4
Dear Lance,
First, I would take a bright flashlight and check for bent pins in the nanoFlash.
Please check both slots.
The DMA error message indicates that we cannot perform a high speed (Direct Memory Access) Read from the CompactFlash card.
Do other cards format ok?
Dan Keaton
Augusta Georgia
Old November 21st, 2013, 03:59 PM   #5
Dear Dan,
I have managed to get the Nanoflash under a microscope and all pins in slot 1 and 2 are not bent, I also examined the connection socket of the Delkin card in case there may be any foreign debris and all sockets are clear. Mechanically both card and Nano flash are clear, I can also format other CF cards in both slots of the Nanoflash with no problems. I now know the card is now stuffed but it would have been nice to know what or why this has occurred. I will now have to put Delkin and Gmonster cards into the same do not buy category as both have now exhibited unexplained errors.
Old November 23rd, 2013, 12:51 AM   #6
Dear Lance,
I will discuss this with Delkin.
Which type/speed of card were you using?
Dan Keaton
Augusta Georgia
Old November 26th, 2013, 02:36 PM   #7
Thanks Dan the card in question is a Delkin CompactFlash Pro UDMA 64gb 420x 63MB/s card.
Old November 26th, 2013, 03:23 PM   #8
Dear Lance,
I have notified our Delkin representative.
Respectfully,
Dan Keaton
Augusta Georgia
Old November 26th, 2013, 04:20 PM   #9
Dear Lance,
I have notified our Delkin Representative, Scott Clark.
He has registered for this forum, and is awaiting approval to post a reply.
He told me:
"It seems this card has been corrupted and needs to be replaced."
Delkin stands behind their products.
Respectfully,
Dan Keaton
Augusta Georgia
Dan Keaton is offline   Reply
