Problem with importing mxf Files in Avid Liquid 7.2 at DVinfo.net
Convergent Design Odyssey
Old December 28th, 2012, 11:40 AM   #1
Hello,
I have the following Problem and help would be really appreciated.
I can import 50 mbit mxf Files into Avid Liquid Edition 7.2 but only the Video gets imported and not the Audio..
Also when i convert the mxf to mpg only one Audio Channel gets converted and the other is missing.
I am using Aunsoft for this.
What i can do is switch from 0x3 to 0x4 Audio Stream in the Clip Properties and this way i can convert the other Audio Channel, but only the other Audio Channel.
Of course it would be perfect to convert just once and then have both Audio Channels present.
So. If there is a Way to import the Audio with MXF Files this would be perfect.
If not than converting is fine but i don't want to convert 2 Times to get both Audio Channels.
I did try some other converters like Brorsoft but they all work kind of the same Way..
Please recognize that this is not Media Composer so link to AMA is not working..Believe me, I tried this..
Also Sony Clip Browser is not helping in any Way.. Export to MXF for NLE is not available..
Probably because i alrady have a MXF File..
thanks in Advance :)
Philipp Steiner is offline   Reply
