Camera recording to SD will Nanoflash record HD? - Page 2 at DVinfo.net
Convergent Design Odyssey
Old November 14th, 2013, 11:33 AM   #16
Re: Camera recording to SD will Nanoflash record HD?
That would mean that you were triggering on incrementing timecode.
This will work, if the camera outputs timecode when in HD-SDI or SD-SDI mode.
Since you were in SD, timecode may or may not have been coming over the SD-SDI signal.
Do you mean via SD-SDI or HDMI? I assume that it was SD-SDI since you answered Yes to Question 2.
Did you have Video|E to E Direct on?
SD over HDMI is not supported in the nanoFlash, but it may have worked if E to E Direct was on, and it was a frame rate and mode supported by the projector.
SD over SD-SDI should have worked, if E to E Direct was on, and may have worked if E to E Direct was off, depending on the frame rate/mode and other settings,
[/QUOTE]
Sorry for the delay,
Yes, SD over SDI.
E to E direct is not on, (not ticked)
Thanks Dan.
Anthony McErlean is offline   Reply With Quote
Old November 16th, 2013, 08:18 AM   #17
Dear Anthony,
If you are in a position to do so, please test with Video|E to E Direct| On (Checked)
Respectfully,
Dan Keaton
Augusta Georgia
Old November 17th, 2013, 05:02 AM   #18
Thanks Dan, will try that too.
Old November 18th, 2013, 11:23 AM   #19
Originally Posted by John Mitchell View Post
Anthony - you have to set this up in camera. Set your camera to record in HD then set the SDI output to downconvert to SD (usually squeeze for 16x9) - the nano should then recognise the SD signal automatically.
Hello John,
Had a looks at the SDI out settings from my PMW320 but don't see where I can change it to SD.
Down converter is already set at squeeze.
Thanks.
Old November 18th, 2013, 11:30 AM   #20
Dear Anthony,
Respectfully,
Dan, I tested with E to E Direct checked but still cant get SD out from the NF while the camera is set to HD.
Perhaps I'm doing something wrong?
Thank you.
Old November 20th, 2013, 06:29 AM   #21
Dear Anthony,
You stated that you can't get SD out of the nanoFlash while the camera is set to HD.
Is the camera outputting SD over the HD-SDI output that you are using to feed the nanoFlash?
If you connect this HD-SDI cable to a monitor do you see SD?
The nanoFlash cannot downconvert HD to SD.
Respectfully,
Dan Keaton
Augusta Georgia
Old November 20th, 2013, 11:28 AM   #22
Hello Dan
Respectfully,
That must be the problen then.
The only way I can get the NF to record in SD is when the camera is set to SD.
It looks like I need a Mini converter of some sort then, to let me output to SD while the camera records in HD.
Thanks Dan for all your help.
Old November 20th, 2013, 04:43 PM   #23
Hi Anthony,
I have the PMW350 and almost 90% of my works are done paired with a nano flash, I either record SD or HD on the nano flash, depends on client's needs, on board (sxs) I always record HD.
Never had problems to do that and I have done it a lot with the sd option!
When you set in the menu Input/Output: the Output& i.LINK to sd & dv the nano flash automatically detect the sd signal mode and i record mxf 50mb sd...I know it's stupid to say but did you check that you have the sdi output set to ON!?
regards
Samer
PDW-F800.PXW-X200.Odyssey7Q+.A7S.www.videoshot.it-Videoshot
Samer Aslan is offline   Reply
