Mounting Nanoflash to EX1r at DVinfo.net
Convergent Design Odyssey
Old October 28th, 2012, 12:14 PM   #1
Hello,
I'm going to be investing in a Nanoflash for my EX1r to get higher bitrate recordings, and I'm planning on powering it with the EX1/d-tap Swit batteries.
What sorts of ways are there to mount the nanoflash with the EX1r? I'd like to leave the hotshoe free for potentially using an H4N. I did look into a rails system to mount the nanoflash behind the camera, so it would still be easily mounted to a tripod/shoulder support.
Any ideas?!
Cheers,
Ollie
Ollie Needham is offline   Reply With Quote
Old October 28th, 2012, 05:26 PM   #2
Re: Mounting Nanoflash to EX1r
Westside av and dm accessories have well designed solutions
Old October 28th, 2012, 10:43 PM   #3
I use a Noga NF1108CA CineArm with both ends having 1/4'' threaded screws and screw it into the back 1/4'' screwhole on the handle.
B&H link: http://www.bhphotovideo.com/c/product/649743-REG/Noga_NF1108CA_NF1108CA_Cine_Arm.html
And I have a photo with the Nano equipped on the EX1R: https://plus.google.com/photos/10501...71807731889090
If you have already attached the rear cold shoe, this would mean you would have to disassemble that to use this configuration. If you're getting an EX1R new, they don't attach the rear cold shoe at the factory so you'll be fine.
I've been using the combo and it sped up post production because of the MOV format and FCP7. Also like the image quality 100Mbps Long-GOP produces. I unfortunately ran out of budget to get decent sized CF cards so I haven't been able to use it as much as I would like to. It also breathed life into my HC7 as well.
Old October 29th, 2012, 08:55 AM   #4
In regards to mounting Nano flash.
I have had great success with the "Juice design" base plate & arm for EX-1R.
Very solid & out of the way.
Juice Designs — EX1 / EX1R Base Plate
Paul DeBaets is offline   Reply With Quote
Old October 29th, 2012, 09:29 AM   #5
You should check out Westside AV they have great options at fantastic prices. Olof is a pleasure to worth with and they are a sponsor on DVinfo.net.
Westside A V Home Page
Paul Cronin
www.paulcroninstudios.com
Paul Cronin is offline   Reply
