Playback to HDMI monitor? at DVinfo.net
Convergent Design Odyssey
Old August 1st, 2012, 10:34 PM   #1
I recently got a nanoFlash and a IndiPro 5" HDMI monitor, to use with my Panasonic AF100.
To use the monitor while recording at 24fps, I have to set the E-to-E to On. No problem. But when I want to playback the recording I just made, the monitor says Unsupported.
Now, If I record without any 3:2 pulldown removal anywhere, then yes I can view playback on the monitor; but then when I load the video into Vegas Pro 10, I see 30 frames per second. As far as I know, Vegas has no way to do 3:2 pulldown removal.
So I seem to be stuck without any way to review a 24fps video in the field. Am I missing some obvious solution?
-- Ken
Ken Hull is offline   Reply With Quote
Old August 2nd, 2012, 08:35 AM   #2
Re: Playback to HDMI monitor?
Dear Ken,
Many HDMI monitors cannot handle a 1080p24 signal or 1080psf24.
Please feel free to call me so I can discuss this in detail with you.
My numbers are at the bottom of this link:
Support | Convergent Design
HD-SDI monitors can handle a 1080p24 and 1080psf24 signal, but I realize that this is not much help to you right now.
I assume that you have your AF100 set to output 1080p24 or 1080psf24.
Or do you have it set to output 1080p24 with 3:2 Pulldown? This is sometimes called 1080p24 over 60.
Dan Keaton
Augusta Georgia
Old August 2nd, 2012, 07:53 PM   #3
I think that what you're seeking is a playback telecine of 24p to 60i to a HDMI monitor. This is currently not possible in the current Nanoflash firmware, however, you can preview the clips on a computer in progressive.
For recording, PsF is a better recording mode for recording progressive images. Pulldown detection relies on whether it can detect a cadence for inversing telecine. If it can't, the Nanoflash will refuse to accept signals and will not record.
Old August 3rd, 2012, 01:23 AM   #4
Dan and Jack,
Thanks for the responses. It looks like I made the wrong choice of monitor for my specific needs. I'm now looking at the specs and prices for other monitors. The HD-SDI monitors are a bit pricey for me. But Marshall makes an HDMI monitor, the V-LCD51 5" On-Camera Monitor, which they claim can handle "1080p (30 / 29.97/ 25 / 24 / 24sF/ 23.98 / 23.98sF)". Does this sound like it would handle playback from the nanoFlash of recordings done with "Record PSF->Progressive" and "Remove 3:2 Pulldown"?
Marshall:
http://www.bhphotovideo.com/c/product/867526-REG/Marshall_Electronics_V_LCD51_Marshall_Electronics_5.html
Also, the IKAN:
http://www.bhphotovideo.com/c/product/859324-REG/ikan__Ikan_VK7_7_HDMI.html
Ken
Old August 3rd, 2012, 01:55 AM   #5
Hello Ken,
you may consider the Swit 's 5" LCD monitor with both HDMI and 3G SDI inputs as well.
S-1051H :
S-1051H 5-inch 3GSDI&HDMI LCD monitor
Stewart Chong
Hong Kong
Camera expert reseller and rental of Nanoflash / Gemini 444 and Swit products.
FB: stewart chong
e: stewart@wowdigitainment.com
Stewart Chong is offline   Reply With Quote
Old August 3rd, 2012, 10:24 AM   #6
You might want to look at the SmallHD monitor choices as well.
John Richard is offline   Reply With Quote
Old August 3rd, 2012, 11:27 AM   #7
Dear Ken,
The specifications that you listed seem to be fine.
However, since I have not personally tested these monitors, it would be best for others with actual experience to comment.
Dan Keaton
Augusta Georgia
Old August 12th, 2012, 12:40 AM   #8
Thanks everyone for your input. I decided to go with the Marshall V-LCD51 5" monitor. It arrived Thursday, and it works great! It's an HDMI monitor that can handle video from which 3:2 pulldown has been removed... no problems.
I was pleasantly surprised to find that it does peaking with a B+W display and red peaking highlights, as well as pixel-to-pixel magnification, and can do both at the same time. It also has Marshall's false colors filter for exposure judging.
