Does the nanoFlash do cross conversion to HDMI out? at DVinfo.net
Convergent Design Odyssey
Old July 3rd, 2012, 02:53 PM   #1
First time I have tried this but with no success..
Using HD-SDI input and taking an HDMI out to the monitor. Does the nanoFlash do cross conversion from HD-SDI to HDMI?
Old July 3rd, 2012, 03:00 PM   #2
Re: Does the nanoFlash do cross conversion to HDMI out?
Dear Andrew,
Yes.
If the input to the nanoFlash is either HD-SDI or HDMI, then both outputs are active simultaneously.
But, HDMI has certain frame rate limitations.
For example, one may have to have 3:2 Pulldown added to work with certain HDMI Monitors.
Please note that one can enable E to E Direct, Menu Item: Video|E to E Direct (checked).
This allows one to accept a 1080p24 signal, with 3:2 Pulldown, so it can go out to an HDMI Monitor, and one can set other options, such as Video|3:2 Pulldown Removal so that the nanoFlash records pure 1080p24 all the while sending out 1080p24 over 60 (with 3:2 pulldown) to the HDMI Monitor.
Dan Keaton
Augusta Georgia
Old August 4th, 2012, 09:07 AM   #3
For those tripping on this thread in the future... I discovered my problem was a bad HDMI cable. It worked perfectly once I swapped the cable.
Old August 4th, 2012, 09:08 AM   #4
Dear Andrew,
Thank you very much for posting the resolution to the problem.
Dan Keaton
Augusta Georgia
Old August 5th, 2012, 06:29 AM   #5
This works OK with my EX1->HD-SDI->nanoFlash->HDMI->Marshall monitor (or Zacuto EVF).
One thing to remember though: with this connection, there is no recording indicator (red bar at the bottom) visible in the HDMI monitor (or EVF, for that matter). Quite unfortunate, actually :(
Old August 8th, 2012, 06:31 PM   #6
Contributor
Well you have to send a clean signal to the Nano to record - plenty of cameras would have the option to overlay info on the SDI output but it would make your Nano recording useless.
John Mitchell is offline   Reply With Quote
Old August 9th, 2012, 12:41 AM   #7
John, I mean the nF's own recording indicator; this one is superimposed on nF output but only works with HD-SDI input...
Old August 14th, 2012, 11:29 AM   #8
Piotr -
I think that if you check the 'E-to-E direct' box on the Nano menu that the Record Indicator Bar shows properly. I have an HDMI client monitor and the red bar shows them when I'm recording (and I'm feeding the NanoFlash from an HD-SDI output on the camera.)
Dave Sperling is offline   Reply With Quote
Old August 14th, 2012, 11:35 AM   #9
This is why I said explicitly "only works with HD-SDI input...".
Meaning, that when the nano is recording from the camera's HDMI out, there is NO recording indicator bar.
Old August 14th, 2012, 11:37 AM   #10
Sorry, my confusion ...
