Nanoflash doesn't receive Hdsdi signal at DVinfo.net
Convergent Design Odyssey
Old June 18th, 2012, 03:43 PM   #1
Hello,
since my last shoot yesterday I've been experiencing the following problem:
I can't get any proper HDSDI feed into my nanoflash. it just won't take it. When I switch my camera to SDSDI a signal incl. proper timecode is received. When I switch it back to HDSDI the signal incl timecode doesn't get through at all. Tried different cables and different cameras. HDSDI stream from my cameras are generally working fine. I tested 3 different cameras. It's the nanoflash that's behaving very strangely since this past shoot. Ok, we had a pretty warm day but I've used the nanoflash in harsher conditions than this. Am running latest firmware, MXF, 50Mbit. Has anyone had this or a similar problem yet? Can anyone also tell me: where do I send it in when a problem like this occurs?
Thanks for your help.
Emanuel Altenburger is offline   Reply With Quote
Old June 19th, 2012, 03:09 AM   #2
Re: Nanoflash doesn't receive Hdsdi signal
Hi There. I am Mike Wattley, I am Distribution Manager at Symbiosis - we are the EMEA Distributor for Convergent Design. If you want to email me (mike@symbiosis.eu) with the details of the unit (serial number and dealer your purchased from) we can provide local technical support I can arrange for the unit to be RMA'd should that be necessary.
Mike
Mike Wattley is offline   Reply With Quote
Old June 20th, 2012, 02:40 AM   #3
Dear Emanuel,
Based on your description of the problem, I suspect a cable issue.
Are your HD-SDI cables True 75 Ohm, and do they have 75 Ohm connectors?
A 50 Ohm connector or cable can have these problems and may still work in SD, but not in HD.
All of my contact information is in this link:
Support | Convergent Design
Please feel free to call me. My Skype account is listed also.
Alternatively, please post any information printed on the cable and/or connectors.
Dan Keaton
Augusta Georgia
Old June 20th, 2012, 03:12 AM   #4
Hi Dan
I have already spoken with Emanuel, and sent out a replacement demo unit whilst his unit is repaired. The issue was not with the cables, I will ichat you to explain what the issue was, having spoken with the technicians at Convergent.
Cheers
Mike
Old July 3rd, 2012, 02:52 PM   #5
moved post.
Andrew Stone is offline   Reply
