SD SDI in SD HDMI out at DVinfo.net
Convergent Design Odyssey
Old May 16th, 2012, 08:10 PM   #1
Hi there,
We have an application where we need to send an SD SDI signal into the Nanoflash and have a passthrough signal over the HDMI out.
When the input is set to HD, the output is able to be viewed fine on an external HDMI monitor. Howver when the signal is switched to SD, though the Nanoflash recognizes it is SD and is even able to record it, it is unable to send the signal through the HDMI out.
Any ideas?
Martin
Martin Kolditz is offline   Reply With Quote
Old May 16th, 2012, 08:37 PM   #2
Re: SD SDI in SD HDMI out
It clearly states in the documentation that SD HDMI is currently not supported. Page 38 of the manual. (for which I've put a link to below)
http://www.matrixvideo.ca/pdf_folder...ash_Manual.pdf
Old May 17th, 2012, 06:43 PM   #3
Great, thanks for pointing that out. Usage of the Nanoflash up to now has been pretty trouble free so there was no need for the user manual up to now...
Old May 17th, 2012, 06:46 PM   #4
Also, the latest firmware does not support SD HDMI recording neither. No word on when that will be fixed as that was a feature not often requested.
Jack Zhang is offline   Reply
