slow-mo
can anybody give me the settings for doing slo-mo with the nano, i can do time lapse but need to set the nano for sl-mo many thanks
Ian
Ian Thomas. Thomas Video Productions |
Re: slow-mo
Look under Video -> Crank.
If you're in 60p, and you want 24p slow-mo, set the 1st option to 24 and the 2nd option to 60. If you're in 50p and you want 25p slow-mo, set the first option to 25 and the 2nd option to 50. It only works in 720p mode. 1080p will not go as high as 60. Be sure to checkmark the box to turn the feature on. |
Re: slow-mo
Thanks Jack will try that
Re: slow-mo
I know this will sound silly sould you be recording slo-mo on the camera as well
#5 |
Re: slow-mo
No, it will be full 60p/50p video with audio. There will be no audio on the Nanoflash slow-mo recording, but it will be most likely at the full bitrate at it's regular playback speed of 24p/25p. (Therefore, higher quality than slowing down 60p/50p from the camera in post)
#6 |
Re: slow-mo
You can fast-mo in 1080p ie. shoot/crank at 1-30fps but not slo-mo.
Bit rate is reduced by the crank factor - eg. crank at 50fps for 2x slo-mo at 25fps playback and the result will have half the rate set on the Nano: set the Nano Bit Rate to 220 to get 110 files. |
