720/25p setting HDX900/Nano at DVinfo.net
Convergent Design Odyssey
Old January 20th, 2012, 08:32 PM   #1
Hi there
Sorry quick question.havnt shot in 720p for so long...!!
Set HDX900 to 720p/25p.. do I need to tick the box on the Nano flash 720 50>25 also.. I guess I do..
And un click Record PSF >Prog ?
There something about no playback from the Nano in 720p..? is that right..
Thanks again
Robin Probyn is offline   Reply With Quote
Old January 20th, 2012, 08:50 PM   #2
Re: 720/25p setting HDX900/Nano
Up date..
I have 720h25 bottom left on the nano.. what does the h stand for..?
Thanks again
Old January 21st, 2012, 07:08 AM   #3
Dear Robin,
Here are the nanoFlash settings to use:
For 720p23.98, enable Video|3:2 Pulldown Removal, disable Video|Record PSF > Prog
For 720p25, enable Video|720p 60/50 > 30/25, disable Video|Record PSF > Prog
For 720p29.97, enable Video|720p 60/50 > 30/25, disable Video|Record PSF > Prog
I bumped up my previous post: HDX900 - Major Announcement as this is a cookbook for getting the best out of an HDX900 with a nanoFlash.
When you select 720p 60/50 > 30/25, you will see an "H" in our frame rate display on the nanoFlash.
In this mode, we are removing the duplicate frames, so that 50 frames per second become 25 frames.
To use this mode, please set your camera accordingly, say 720p30 or 720p25.
The nanoFlash does not playback any 720p footage under 50 frames per second.
Dan Keaton
Augusta Georgia
Old January 21st, 2012, 07:28 PM   #4
Hi Dan
Ok thanks.. yes I had it set up.. just wanted to check !!
Thanks again
