Converting Gemini dpx files at DVinfo.net
Convergent Design Odyssey
Old January 16th, 2012, 12:22 AM   #1
I'm trying to use Adobe Media Encoder to convert Gemini files to Cineform AVI. It runs fine but the video looks very jumpy when played back -- almost looks like it's missing frames. I'm converting 23.98 fps .
Any advice?
Thanks.
Steve Kimmel is offline   Reply With Quote
Old January 16th, 2012, 01:31 AM   #2
Re: Converting Gemini dpx files
If it helps any, I am converting a 10 second clip and it's converting into an about 8 second clip. So, looks like it's dropping frames somewhere.
I was just able to try this with the Cineform DPX decoder and it worked fine (10 second clip).
Thanks for any advice.
Old January 16th, 2012, 01:42 AM   #3
Check that it's recognising the correct frame rate for the DPX file. You may need to use the "Interpret Footage" function to set the correct frame rate. If your default settings are for 30fps 30p/60i then it will treat your 23.98fps DPX footage as 30p and that's why it only comes out at 8 sec and not 10 secs and will be a bit jumpy.
Old January 16th, 2012, 09:09 AM   #4
Thanks Alister! That's exactly what was happening!
Is there a way to fix this as a preference or does one have to do this with each import?
Thanks again
Old January 16th, 2012, 11:08 AM   #5
Sponsor: Convergent Design
Hello Steve,
You should be able to set this under Preferences, all keep in Mind unless you are playing the footage off a Raid, the footage will most likely not playback smoothly in real time,
Also Thank you Alister for your response,
As a Test you can always check your files with After Effects, we find that it plays back DPX files very well, as long as the drive it is being played off of is fast enough.
Best Regards
Andy Mangrum, Tech Support Convergent Design, Inc
Andy Mangrum is offline   Reply With Quote
Old January 16th, 2012, 11:11 AM   #6
Thanks Andy. I don't see anything in Preferences to set this in Media Encoder. Is there a way to set up the Gemini to flag the footage with the correct frame rate?
Thanks.
Old January 16th, 2012, 06:00 PM   #7
Hello Steve,
This is already set in the Metadata, as well as in every dpx frame,
I will try to look into this tomorrow.
Best Regards
Old January 16th, 2012, 06:58 PM   #8
Thanks Andy. I must say, the files out of the Gemini are stupendous!
Old January 19th, 2012, 09:09 AM   #9
Originally Posted by Andy Mangrum View Post
Hello Steve,
Best Regards
Hi Andy. Have you been able to find anything on this?
Thanks.
Old January 20th, 2012, 09:52 AM   #10
Hey Steve,
Sorry for not getting back to you sooner, I was checking in Preferences and I did not see a way to set the Default,
I will speak with our Adobe to see if there is a way to set it, or if we can have it correctly recognized in the future,
Best Regards
Old January 20th, 2012, 09:59 AM   #11
I think if you change the frame rate under "preferences", "Appearance", it has a knock on effect to the default playback rate for un-recognised files.
Old January 20th, 2012, 10:10 AM   #12
Doesn't seem to work for me -- Mine is set to 24 fps but still showing Gemini files as 29.97 fps.
