3D Nano Flash settings sticky ?? at DVinfo.net
Convergent Design Odyssey
Old September 18th, 2011, 05:20 PM   #1
I've probably pestered Dan way too many times about the "correct" settings for the 3D Nano Flash setup, so I'm thinking it would be very helpful to have a permanent "sticky" FAQ at the top of the forum that we could access via iPhone or other devices on set to double check our 3D menu settings.
It's a simple list of settings for Master/Slave setup, but if you get just one setting wrong then all of the features are not available or working properly.
I've printed out a version, but the last 3D shoot I was on I didn't have it with me or online so I had to go by memory - and at my age good memory is just a memory.
So I'll put this out for the good folks at C-D to decide.
Old September 18th, 2011, 06:26 PM   #2
3D nanoFlash Settings for 1080p24
These menu settings are for the nano3D, and are sepecifically set up for 1080p24.
Other framerates may be used with appropriate adjustments.
The firmware on both units must be 1.6.246, or a later 3D version.
1.6.248 is a 2D firmware version and not suitable for 3D.
If the nano3D is to be used for 2D work, then please load the 1.6.248 firmware on both units.
You can easily reload the 1.6.246 nano3D firmware when you want to record 3D again.
The nano3D must be triggered using the remote control, as supplied with the nano3D.
The Remote Control Y-Cable must be installed, connected to both units.
Master Unit = Left Eye
Slave Unit = Right Eye
The cameras must be genlocked.
(If the cameras are not truely genlocked, then only the "Left Eye" will be seen.
The "Side by Side" output will only contain the "Left Eye" if the cameras are not genlocked.)
The 9” HDMI cable (Type C) to Type C must be installed properly with the nano3D.
The HDMI Out of the Slave Unit (Right Eye) must be connected to the HDMI In of the Master Unit (Left Eye).
(The nano3D does an excellent job of recording 3D. It does not do an acceptable job of playing back 3D on set at this time, with firmware 1.6.246). If you need immediately playback on set, please contact me.)
These are the settings for when the cameras are sending out 1080p24 (or 1080p23.976).
If your camera is sending out 1080p24 over 60 (with 3-2 Pulldown Removal Added),
then please contact us for advice as adjustments to these setting are required.
With 24p over 60, with Pulldown Frames added, one has to synchronize the cameras to ensure that the pulldown sequences are the same. This is in addition to genlocking the cameras.
If possible, please have your camera output 1080p24.
The Left Eye must be connected to the Master Unit, and
The Right Eye must be connected to the Slave Unit.
System Menu
Max Files Size 100%
Source SDI
File, on Left (Master Unit), set 1L then the clip number (Set Initially to 001), then 001.MOV or MXF (your choice depending on your editor)
File, on Right, set 1R then the clip number (Set Initially to 001), then 001.MOV or MXF (your choice depending on your editor)
Trigger: Remote Record (this is critical, do not use a different option)
Duration: Unchecked
Timecode: Source: LTC (Send timecode to nano3D via BNC timecode input on the Remote Control cable) or
Timecode: Source Embedded (if appropriate)
Source: SDI
Prebuffer off
Power Saving: Off
Video Menu
Bit-Rate: Your choice over 140 Mbps
Codec: I-Frame (This is critical)
Record PSF>Prog Off
Play PSF> Prog Off (Very Important)
Remove 3:2 Pulldown Off
720p 60/50 >30/25 Off
E to E Direct: Off
T-Lapse Off
Crank Off
Screen Tally Off
Flip V (as desired on left and right)
Flip H (as desired on left and right)
Video 3D Menu
Enable (on Master Unit Only) This is critical
Off (on Slave Unit Only) This is critical
Combine: Side by Side
Record Combined: Off
Play Ref: Ext (HDMI) on Master,
Int on Slave These are critical
Frame Shift 0 (Must be zero if you wish to use any Combine Function other than Side by Side)
Audio:
As desired
I do not recommend that you attempt to switch the nano3D’s into Play. This is critical
Note the above setup is for outputting the combined Side by Side signal via the Master’s unit’s HD-SDI output.
If you are using a consumer television, then you will need an AJA HD-SDI to HDMI converter, a Hi 5 3G model. Other models may not work in your application. For example, a Hi5 (no 3G) will not work with 1080p24.
As always, please feel free to call for assistance.
Respectfully,
Dan M. Keaton
Director of Sales and Marketing
Convergent Design
Here is a link with information how to contact us.
Support Contacts | Convergent Design
Dan Keaton
Augusta Georgia
Old September 21st, 2011, 12:17 PM   #3
Re: 3D Nano Flash settings sticky ??
Great list Dan, now how do we get it posted at the top of the forum as a sticky?
Old September 21st, 2011, 12:41 PM   #4
Dear Bruce,
That is up to the Moderators of DVInfo.net.
Dan Keaton
Augusta Georgia
Old September 22nd, 2011, 11:27 AM   #5
Dear Moderators of DVInfo.net, please position the second post on this thread (by Dan Keaton) as a permanent sticky on this forum to assist all users of Convergent Design's 3D Nano Flash recorder.
Old September 22nd, 2011, 11:55 AM   #6
In the interim while the moderators are deciding, I have posted Dan's instruction sheet for 3D Nano setup on my blog/website as a September post. All 3D Nano users should feel free to view and copy/paste to save for future reference.
www.primetime3d.net
Bruce Schultz is offline   Reply
