Card loses name? at DVinfo.net
Convergent Design Odyssey
Old August 26th, 2011, 12:01 AM   #1
Card loses name?
Have a Delkin 64 card.. that i have named CARD 2,from its icon on the computer.. MBP.. but when I put it into the nanoflash it says NO NAME.. no problems with other cards.. and the card itself records ok...worked fine for ages.. .. anything that would cause this ?
Robin Probyn is offline   Reply With Quote
Old August 26th, 2011, 07:36 AM   #2
Re: Card loses name?
Dear Robin,
Are you changing the "Volume Label" of the card on your computer?
When you put the card back into your computer is the "Volume Label", "Card 2", still visible?
If you change the "Volume Label" in your computer, then remove the card, and reinsert it, is the "Volume Label" remain unchanged?
Dan Keaton
Augusta Georgia
Old August 26th, 2011, 09:00 AM   #3
Did you reformat it by any chance?
Adam Stanislav is offline   Reply With Quote
Old August 26th, 2011, 10:12 AM   #4
Dear Friends,
If one reformats a CompactFlash card, in the nanoFlash, we preserve the Volume Label from one format to another.
This may not occur if the card is formatted in another device, such as a computer.
The correct procedure, in order to ensure reliable operation of the nanoFlash, is to always format the CompactFlash card in the nanoFlash prior to recording.
Deleting files from the CompactFlash card using another device, then recording in the nanoFlash will cause problems.
Formatting a CompactFlash card in another device, and then not formatting the card in the nanoFlash will also cause problems.
Dan Keaton
Augusta Georgia
Old August 26th, 2011, 10:17 AM   #5
Thanks, Dan. That’s good to know.
Old August 28th, 2011, 11:22 PM   #6
Dear Robin,
Hi Dan
Seems to be ok now.. might have been something that Klix had done to it..? in the checking mode..?
Quick question.. if Iam recording onto say Card 1.. I stop recording for the day.. take out the card.. then next day put in Card 1 again.. (without having down loaded it) it will be ok to just go on recording as normal would it not..?
Thanks again
Robin
Old August 29th, 2011, 01:42 AM   #7
Dear Robin,
Yes, that is perfectly ok.
Dan Keaton
Augusta Georgia
Old August 29th, 2011, 09:46 AM   #8
Sponsor: Convergent Design
Hello Robin,
If you have KLIX preform a Test, The Compact Flash card will need to be formated after, since it will erase the formating during the testing process.
Hope that Helps
Best Regards
Andy Mangrum, Tech Support Convergent Design, Inc
Andy Mangrum is offline   Reply With Quote
Old August 29th, 2011, 07:35 PM   #9
Hi Andy/Dan
Ok many thanks..
Old September 1st, 2011, 02:21 AM   #10
Originally Posted by Andy Mangrum View Post
Hello Robin,
Hope that Helps
Best Regards
Card all fine.. all working .. no problems..
