1080p 24 Problem From FS100 to Nanoflash at DVinfo.net
Convergent Design Odyssey
Old July 2nd, 2011, 01:34 AM   #1
Hello Guys. Last Week I get From Sony PMW-f3 and NEX-FS100. yes both are amazing cameras but i have problem with FS100 output on NanoFlash. When I set on camera 24p 1080p output Nanoflash loosing Source . on 720p everything is ok. If i can not record From FS100 on NanoFlash 1080p I will very disappoint.
David Imedashvili is offline   Reply With Quote
Old July 2nd, 2011, 01:32 PM   #2
Re: 1080p 24 Problem From FS100 to Nanoflash
If I recall correctly, the one time I used the FS100 shooting 24p with my NanoFlash I had the HDMI output at 1080i with pulldown and set the NanoFlash to remove the 3:2 pulldown. It all worked just fine, and the producer loved the Nano footage - he even sent me a text afterwards saying 'Nano Rocks!'
(I don't own an FS100, but that day the producer brought one along as a second camera to go with my F3 -- hence I can't test anything presently)
I often do the same kind of thing with the F3 (or even the EX1), integrating the 3:2 pulldown in the camera 1080i output -- since then setting the NanoFlash on E-to-E allows me to use HDMI client monitors that don't support 24p directly, while having the NanoFlash remove the 3:2 pulldown so I'm recording in 24P.
One thing - occasionally you may need to power the Nano off/on if you've made a change to the HDMI signal.
Dave Sperling is offline   Reply With Quote
Old July 2nd, 2011, 04:59 PM   #3
Thank You Dave Sperling For your Help. I already setup connection with this two animals.
Old July 2nd, 2011, 05:04 PM   #4
Great Device is NanoFlash. I own it from 2009 and it works great. I already made Future Film with NanoFlash, EX1 and Letus Ultimate. Ocnebis qalaqi (2010)
this is Trailer.
Old July 2nd, 2011, 05:07 PM   #5
