Actual frame dimensions at 1080p - Page 2 at DVinfo.net
Convergent Design Odyssey
Old April 26th, 2011, 05:55 AM   #16
Re: Actual frame dimensions at 1080p
Sorry to disagree.
VLC is just a player without any aim for accuracy, and without any displaying option.
QT shows things as-they-are.
if you want to fix the black-side-line, dig about APERTURE.
rafael
Rafael Amador is offline   Reply With Quote
Old April 26th, 2011, 08:13 AM   #17
To be sure things are clear: I do not care about black lines or a smaller window that QT opens to play the clips. Ultimately I only want to know that there is not a surprise somewhere that my clips are almost, but not completely, full hd. I am sure there is nothing to worry about. When a topclass company like CD makes a topclass product like the nano and every information says it is 1920, than it is 1920. Period. But still QT at 'actual size' does not fill the full width of the 1920 wide screen, which made me wonder: why?
Cees van Kempen is offline   Reply With Quote
Old April 26th, 2011, 09:03 AM   #18
Sponsor: Convergent Design
Hello
Also in Final Cut Pro, if you select a file then press (Apple Key)+9, it should show item properties of a selected file in the working area, this should also reflect 1920x1080 (As you would typically see from Movie inspector in QT Player)
Best Regards
Andy Mangrum, Tech Support Convergent Design, Inc
Andy Mangrum is offline   Reply With Quote
Old April 28th, 2011, 02:41 AM   #19
Hi
I guess that the players QTplayer, VLC, MPC or others are not reproducing the stuff pixel to pixel on your PC screen !
Bo Skelmose is offline   Reply
