Audio Settings, nanoFlash and XLH1 at DVinfo.net
Convergent Design Odyssey
Old April 13th, 2011, 06:54 AM   #1
Please can someone remind me what these should be, on/in the camera, and on/in the nanoFlash.
I am using a Audiotechnica AT897 shotgun mike (mono) attached to a rear XLR terminal.
All was okay until I had to reset my settings post the last nano firmware update.
No problem in recording audio to tape,
Ron
Ronald Jackson is offline   Reply With Quote
Old April 13th, 2011, 07:04 AM   #2
Re: Audio Settings, nanoFlash and XLH1
In the audio menu of the Nano, you have to set the input audio to "Analog".
http://www.songesdemoai.com/
Ronan Fournier is offline   Reply With Quote
Old April 13th, 2011, 10:40 AM   #3
Thanks Ronan, I've done that but no audio,
Ron
Old April 13th, 2011, 11:35 AM   #4
Sponsor: Convergent Design
Hello Ronald,
Is your mic directly plugged into the Camera or the nanoFlash? also do you have phantom power on to power the mic? or is it battery powered?
If the Mic is connected into your camera, you must enable it in the camera, to use the external Mic, and set the nanoFlash for Embedded Audio.
If the Mic is connected into your nanoFlash, it must either be battery powered, or come from a sound board, since the nanoFlash cannot supply +40V threw the 3.5mm jack, then the nanoFlash would be set for Analog, and under analog settings you can adjust the Gain in, Gain out only applied to the headphone out, not the recording,
Best Regards
Andy Mangrum, Tech Support Convergent Design, Inc
Andy Mangrum is offline   Reply With Quote
Old April 13th, 2011, 11:36 AM   #5
I suppose that you are sure of your connections (RCA ouput on the XLH1 to mini-jack in put on the Nano).
Here are my audio settings with my XLH1 (original version)
In : Analog
In the Analog Settings menu of the Nano : Mix In should be Stereo Unbal, PreAmp 0db, Gain In -4db, Gain Out 0,3959db.
Record channels 2
Monitor channels 1 & 2
Hope this helps…
Old April 13th, 2011, 12:37 PM   #6
Thanks chaps. Will give it a go tomorrow. Just returned from the local (pub) so best to wait a while,
Ron
Old April 14th, 2011, 07:20 AM   #7
Got it working although according to the nano display only recording to one channel but as I'm using a mono mike presumably no problem.
Ron
Old April 14th, 2011, 07:38 AM   #8
Find I get no output from either audio in/out socket on the XLH1 if I plug in the red of the two, red and white jacks on the 3.5mm stereo cable. If I plug the white jack in, then I get output from both sockets, i.e. I can plug white into white or white into red and get output.
If, however, I plug the yellow jack (sounds like a disease I know) into either the white or red socket along with the white jack in the opposite jack I get output on both channels per the nano display.
Thus the red jack does not work, the red and yellow work either individually or in tandem.
Anyway, it works!
Ron
