Premiere Pro CS4 Audio Problem with NanoFalsh Files at DVinfo.net
Convergent Design Odyssey
Old March 11th, 2011, 10:40 AM   #1
We are trying to edit video footage recorded at 1920x1080 @ 100mbps, recorded on the NanoFlash to compact flash cards (.MXF files) in Premiere Pro CS4 (Windows XP). The editor has the MainConcept MPEG Pro HD 4.1 plugin installed. Premiere will import and play the video files, and import the 4 video tracks, but there is no data in the audio tracks i.e. no sound and no waveform. The audio is 48khz 24-bit. Premiere appears to attempt to conform the audio, and even creates .cfa files, but again, no data, no sound. We cannot find a MainConcept 100mbps preset, nor an option to select 100mbps. Any thoughts on why I am not getting any audio when I drag over these files?
Playback works greats on VLC.
Camera used ; HDX-900 / 1080 / 23.9
Dusty Powers is offline   Reply With Quote
Old March 11th, 2011, 01:26 PM   #2
Sponsor: Convergent Design
Re: Premiere Pro CS4 Audio Problem with NanoFalsh Files
Hello Dusty,
Have you tried playback in Sony XDCAM viewer? it displays much more information and is a much better tool than VLC,
Sony : XDCAM & XDCAM EX Software Downloads : United Kingdom
Can you verify that there is audio present in the files using Sony XDCAM viewer, or playing your files back out of the nanoFlash?
I will try to replicate the Issue here,
Also under preferences, do you have your audio device set correctly? (set for your external speakers etc) and not to play audio out of a capture card, etc.
Best Regards
Andy Mangrum, Tech Support Convergent Design, Inc
Andy Mangrum is offline   Reply With Quote
Old March 11th, 2011, 06:19 PM   #3
Andy:
Thanks for your suggestion.
We have verified that there is audio in the files via VLC. We know that there is audio.
The thought is that the audio configuration is correct as evidenced by the fact that the “stripped” audio files play fine.
We also rendered the file earlier just to see if it would change things and that didn’t work either.
I get sense that there is a problem between the MainConcept plugin and CS4 in the processing of the NanoFlash files.
Old March 12th, 2011, 11:34 AM   #4
The Fix for Nanoflash files and Adobe P Pro comes in the 5.03 Version, an update to Version 5. There PPPro handles the Nanoflash and it sound files without problem. CS4 does not have the native ability to handle nanoflash sound files correctly. You need the CS5 for that to work.
Roman
Roman Stikel is offline   Reply With Quote
Old March 13th, 2011, 10:25 AM   #5
Roman,
Is there a fix either in PPro CS4 or in Nanoflash to get the audio to work? Upgrading to CS5 is a pretty expensive proposition.
Steve Siegel is offline   Reply With Quote
Old March 13th, 2011, 11:08 AM   #6
Roman and Steve:
As per CD, it is my understanding that the MainConcept MPEG Pro HD 4.1 plugin for CS4 (which is installed) should allow CS4 to work with the NanoFlash files. Please correct me if I'm wrong.
Thank you.
Dusty
Old March 13th, 2011, 02:45 PM   #7
Dear Dusty,
Yes, you are correct.
We need to troubleshoot this issue Steve and Roman.
Here is our contact info (including my phone numbers for 24/7 support):
Support Contacts | Convergent Design
Dan Keaton
Augusta Georgia
Old March 15th, 2011, 08:00 AM   #8
If the Main concept plug in is expensive, might have to look at what the cost would be to upgrade to CS5. It is 64bit native, but with GPU acceleration, it does help to work with those large nanoflash files.
Roman
Old March 16th, 2011, 07:18 AM   #9
Roman:
The MainConcept plug-in has already been purchased. MainConcept as well as Andy Mangrum at Convergent Design is working with us to find a solution. He has our files and I'm sure we will hear something back soon.
Up grading to CS5 might be one way to solve the problem, but if the decision was made to spend any money to upgrade, it would be to a FC Pro system.
Thanks.
