development towards 1080p50/60 at DVinfo.net
Convergent Design Odyssey
Old February 22nd, 2011, 09:05 AM   #1
Dear Dan / CF team,
With the panasonic AF100/101 on the market, 1080p50/60 is now available for many of us, however not with the nano. Is there any devolpments foreseen for an upgrade making this possible with a nano?
Cees
Cees van Kempen is offline   Reply With Quote
Old February 22nd, 2011, 05:03 PM   #2
Re: development towards 1080p50/60
Dear Cees,
In the specific case of the AF100, which uses single-link HD-SDI at 1.485 Gbps, there is not enough bandwidth to output 1080p50, 1080p59.94 or 1080p29.97.
Thus, the nanoFlash never sees these framerates nor does that AF100 output them over HD-SDI.
Dan Keaton
Augusta Georgia
Old February 23rd, 2011, 02:38 AM   #3
Dear Dan,
Thanks for your reply. I did not make my question clear, I also don't own the specific camera I mentioned. It is the general development of camera's moving towards 1080p50/60 that made me wonder if CD is moving the same way.
Cees
Old February 23rd, 2011, 10:58 AM   #4
Dear Cees,
I am most interested in the development of 1080p50, 1080p59.94, and 1080p60 cameras.
Many professionals shoot in 1080 for the outstanding images that can be obtained, especially with the nanoFlash.
However, with single-link HD-SDI, no camera can output 1080p60 over the link. Dual-Link or HD-SDI 3G is required.
But, 720p60 can be transmitted over an HD-SDI single link.
Thus, for slo-mo, 720p60 is typically used.
But, again, I am very interested in 1080p60 over dual-link or 3G as then one can shoot in 1080 and have outstanding slow-mo, such as 1080p24 timeline with a crank speed of 60. This is very desirable.
Dan Keaton
Augusta Georgia
Old February 23rd, 2011, 09:15 PM   #5
1080p50/60 has recently been set as standard for 3D filming.
Please don't miss this important document ( the 274M SMPTE/ EBU standard):
http://tech.ebu.ch/docs/tech/tech3299.pdf
rafael
Rafael Amador is offline   Reply With Quote
Old February 26th, 2011, 12:13 PM   #6
Dear Rafael,
Thank you for posting that document.
It is a very nice reference document, which emphasis on frame rates used in PAL areas.
Dan Keaton
Augusta Georgia
Old February 26th, 2011, 03:28 PM   #7
Hmmm... Strange... Page 8, Table 3, Item 2, states:
Code:
Y’ = 0.2126 R + 0.7152 G’ + 0.0722 B’
I wonder if it is a typo, or if it truly means R rather than R’. Why would it use the linear value of red (R) but the gamma corrected values of green (G’) and blue (B’).
Adam Stanislav is offline   Reply With Quote
Old February 26th, 2011, 09:20 PM   #8
You are right Adam; that's a typo on the BT.709 Y' formula..
As Dan points the paper are for PAL-land time-bases, but much on the information can be extrapolated to NTSC-land.
About 1080p60/50, I don't see the need to going there unless you are making Slow-mow for a BIG screen.
The
Old February 26th, 2011, 10:23 PM   #9
Thanks for confirming that.
Old February 27th, 2011, 08:34 AM   #10
Dan, just wondering, is 720p120 a possibility for a single HDSDI lane?
Scarlet will have this framerate and it would be quite nice to be able to record using the Nano.
Old February 27th, 2011, 10:58 AM   #11
Dear Tim,
I do not know if 720p120 is possible via 1.485 Gbps Single Link HD-SDI.
I will ask our engineers if this is possible with the Sony Codec Module.
It is a very interesting question.
Dan Keaton
Augusta Georgia
Old February 27th, 2011, 04:25 PM   #12
Thanks. Lets hope it is possible.
Old February 27th, 2011, 04:51 PM   #13
720p120 contains 921,600 pixels per frame. Multiplied by 120 gives us 110,592,000 pixels per second. With three color channels, we get 331,776,000 colored pixels per second. With 8 bits each, we get 2,654,208,000 bits per second. That is slightly more than 2.654 Gb/s. Even without any overhead, 2.654 is more than 1.485.
As far as I know, SD-HDI transfers uncompressed 4:4:4 video. If that is the case, the answer to the question is: No, it is not possible.
Old February 27th, 2011, 05:08 PM   #14
On second thought, I think it uses 4:2:2, so we need to take 2/3 of that, giving us 1,769,472,000 bits per second, or slightly more than 1.769 Gbps. Still too much.
Old February 27th, 2011, 06:43 PM   #15
Dear Friends,
Do anyone know of a camera that outputs 720p120 via HD-SDI, single-link, dual-link, or 3G?
It is one thing to record internally at 720p120, quite another to send this out via HD-SDI.
Dan Keaton
Augusta Georgia
Dan Keaton is offline   Reply
