Why Can not make slow motion work? at DVinfo.net
Convergent Design Odyssey
Old February 14th, 2011, 12:12 PM   #1
I have been trying to record with the over/undercranking mode in the nano with this settings:
EX1
720p60
nano set to:
MXF
I Frame: 220Mbps
3:2 Pulldown off
720p 60/50> 30/25 off
Crank _24 60
after 13 seconds of recording it says "lost footage card too slow", I have tried lovering the bit rate and the same result.
I have three cards two Delkin 64GB and a Sandisk Extreme 32GB, same effect in all of them
Am I missing something.
Any advices
Julio Veas P. is offline   Reply With Quote
Old February 14th, 2011, 12:37 PM   #2
I hope I'm wrong but it is my understanding that the EX1 SDI can only output 60i or 24psf.
Daniel Doherty is offline   Reply With Quote
Old February 14th, 2011, 02:14 PM   #3
I can't answer the slo-mo question, but I do know that when I switch my EX1 over to 720/60, my hd-sdi monitor indicates that it's getting a 720p signal, as does the nanoflash.
Dave Sperling is offline   Reply With Quote
Old February 14th, 2011, 04:04 PM   #4
yes, sure it does and it is the way convergent design suggests you should set your camera to..... the problem is that the nanoflash seems to stop recording due to a card being too slow, however it is supposed that the bit rate is adjusted so that it fits the 220 mbit/sec, so in theory the cards are not the problem since they support 220 mbit/sec under normal recording conditions.
Old February 14th, 2011, 04:16 PM   #5
Just solved it, it works with .mov files but not with mxf.
Old February 14th, 2011, 04:40 PM   #6
Julio,
Have you confirmed that you're recording 60 progressive frames per second?
Old February 14th, 2011, 04:55 PM   #7
On page 116 of the EX1 userīs manual says that when you set 720p60 the output of the SDI is 59.94p so it should be recognized progressive by the nano if it the record/progresive is checked in the menu.
Old February 14th, 2011, 05:04 PM   #8
That's excellent news! Thanks.
Old February 23rd, 2011, 07:35 AM   #9
Re: Why Can not make slow motion work?
Hi Guys
I have also tried to get slow mo to work with my ex1 and could not.
So I use the cameras slow mo , at least it works.
Rob Dommermuth is offline   Reply With Quote
Old February 23rd, 2011, 11:07 AM   #10
Dear Rob,
What firmware verion are you using?
As far as I know our slo-mo works.
Please feel free to call me today.
Support Contacts | Convergent Design
Dan Keaton
Augusta Georgia
Dan Keaton is offline   Reply
