Installing nanoFlash Firmware at DVinfo.net
Convergent Design Odyssey
Old January 28th, 2011, 01:16 PM   #1
Dear Friends,
Here are detailed instructions for installing firmware in the nanoFlash.
One may jump from your current release to the latest release.
And, one may re-install an earlier release at any time.
I have written very detailed instructions, but this process is actually relatively easy.
Also, I will be happy to assist via the phone or Skype.
Here is a link to our support phone numbers, my numbers are listed near the bottom:
Support Contacts | Convergent Design
Please go to our website and download the firmware release of your choice.
Just click on the following,
Downloads | Convergent Design | Professional Video Recorders and Converters
Then click on your firmware choice, then click on Save and save it to a folder of your choice.
Unzip it. Mac users may not have to unzip it.
Format a qualified CompactFlash card in your nanoFlash (ensuring that no important footage is on the card first).
Copy the entire unzipped }UPD{ folder to the root directory of a CompactFlash card, and one that has been formatted in the nanoFlash. Do not just copy the contents of the }UPD{ folder, copy the entire folder.
Do not copy it into the }CLP{ folder. When you are done you should have:
}CLP{
}UPD{
STT
Remove all cards from the nanoFlash
Power Off, then Power On the nanoFlash
Put the card with the firmware in the }UPD{ folder, into the nanoFlash
Click OK, to install the firmware release.
Watch as it does Erasing, about 1 minute
Watch as it does Programming, typically under 7 minutes.
When it says Programming …………Done
(Do not be fooled by the progress bar reaching 100%, wait until it says Programming.......Done)
Remove the card.
Power Cycle the nanoFlash.
Perform a System|Restore Defaults (This is required after every firmware update or downgrade.)
(Navigate to System|Restore Defaults, then Press Right Arrow, then Press OK)
Restore all of your menu settings in the nanoFlash.
Then take the card with the }UPD{ firmware to a PC or a Mac, then delete the }UPD{ folder.
Then you may reformat this card in the nanoFlash.
Dan Keaton
Augusta Georgia
Old January 28th, 2011, 03:17 PM   #2
Should make this a sticky.
Is there a way to check which version the nano is currently running?
Simon Wood is offline   Reply With Quote
Old January 28th, 2011, 07:35 PM   #3
Dear Simon,
Yes, go to System|About and Press the Right Arrow.
With 1.6.248, we will also show the firmware version in the System or Main Menu.
Dan Keaton
Augusta Georgia
Old January 29th, 2011, 09:53 PM   #4
I did a firmware update when the latest version (1.6.248) came out and had no problems with Nano operation but I did not do the default restore thing. I just did it to be sure and set everything up again but when I started to record up came .MOV - then I had to figure out how to fix it - it is not in a separate section (File Format) but in the File = .. Dumb question but are most users of the Nano MAC people (reason for MOV being default)? If I had not done the system restore defaults what are the potential dangers? All my previous settings were intact and seemed to be working.
Barry J. Weckesser is offline   Reply With Quote
Old January 30th, 2011, 12:46 AM   #5
Dear Barry,
Quite a few people use Mac's and Final Cut Pro.
There are over a million installed copies of Final Cut Pro.
We have a free utility to convert ".MOV" files to ".MXF". This is a feature of our File Converter software.
After doing a System|Restore Defaults, you may just go to System|File, then press the Right Arrow until your reach ".MOV", then click the Down Arrow, then select ".MXF", ".MPG" or ".MOV", then press OK.
Dan Keaton
Augusta Georgia
Dan Keaton is offline   Reply
