220 mbits workflow
Hi everyone
I have been using my nano with good results For 50-100 mbits long gop, with no issues(FCP editing Color for grading (round trip) and exporting to compressor for H.264 output), however when I use 220 I-Frame, with the same workflow I get more artifacts (twittering - stairsteping) than I get with long gop 50 or 100. Am I doing something wrong? Sequence settings: easy setup for xdcam hd 422 30p, change render codec to prores 422HQ same codec for color any help would be appreciated....thanks |
Hi Julio,
Without knowing what kind of camera you are using and the kind of settings you have on it, one is hard pressed to know what is going on. Just a guess but I would suspect you have some in camera sharpening going on that gets smoothed out at 100 mBit but becomes more noticeable at a higher bitrate. Do you have sharpening settings turned on in your camera? If so try turning it off and do a test shot. |
Hi Andrew
EX-1 Detail: -7 Frequency: +25 Crispening: +20 Cinema +30 Black -3 Everything else set to default I donīt think is the camera since the settings are the same, workflow the same and the only difference is 50 or 220 mbits. thanks |
one other thing
when I watch the footage directly out of the nano on my LCD (not proffesional grade), I donīt see any artifacts, but clearly the image is sharper at 220 mbits. Julio |
