CF Card Error UDMA4:2000 at DVinfo.net
Convergent Design Odyssey
Old November 18th, 2010, 02:02 PM   #1
Hi Dan,
I dug up an old SanDisk Ultra II 1.0GB CF card out of my Nikon gear bag, in the hope that it could be used as an updater/config saver card for my Nano. But, when I insert it into the Nano, I get this message in the Nano's window:
UDMA4:2000
...and I can't even get to the "format card" screen.
Does this mean that this card can't be used at all in the Nano?
Many thanks,
Jeff
Jeff DePonte is offline   Reply With Quote
Old November 18th, 2010, 03:30 PM   #2
Dear Jeff,
Your old SanDisk Ultra II 1.0GB CF is not a card that we have qualified for use with the nanoFlash.
This old card is not a UDMA card and does not meet the performance requirements to work in the nanoFlash.
During the format process in the nanoFlash, besides formatting the card, we test the card.
The UDMA4:2000 error indicates that it did not pass our performance tests.
Thus, it can not be used in the nanoFlash.
We keep a list of qualified cards on our website:
Media | Convergent Design
Dan Keaton
Augusta Georgia
Old November 18th, 2010, 03:45 PM   #3
Hello Dan,
Does this mean that CF cards with 1Gb/2Gb/4Gb/8Gb would not work at all? Do you have a list what kind of CF card of the above size would qualify for that task. It is very pricy to use 32Gb CF card for settings that are only a few Kb., but if their is none, well , so be it....
Cheers
Luben Izov is offline   Reply With Quote
Old November 18th, 2010, 05:09 PM   #4
I wonder if most UDMA rated cards would work for the config files only (no recording or playback).
John Richard is offline   Reply With Quote
Old November 18th, 2010, 06:00 PM   #5
Dear Richard.
We do not test the lower capacity cards.
Generally, a lower capacity card, of the same type and brand will probably work for config files.
Thus a 4 GB SanDisk Extreme III card, for example, should work fine.
Dan Keaton
Augusta Georgia
Old November 18th, 2010, 08:06 PM   #6
Dear Luben,
Sorry, but I did not see your post earlier.
For Config files, I would recommend a low capacity card of the same brand/type of a qualified card.
Dan Keaton
Augusta Georgia
Old November 18th, 2010, 08:24 PM   #7
Thank you Dan! No worries, I thought that your reply to John was actually directed to all of us and it is.
Thank you for the clarification.
Cheers
Old November 18th, 2010, 11:22 PM   #8
Cheapest I can find is $25 for 4GB
Dan,
You think this would work?
Duracell High Speed 4 GB 300X USB 2.0 Compact Flash Card Card UDMA
Jeff
Old November 19th, 2010, 12:54 AM   #9
Dear Jeff,
Yes, I do feel that that card will work as a "Config" card.
We have not tested this card, however, but it has UDMA, and 300x speed according to the spec.
But, it says "USB 2.0" which is just strange as CompactFlash cards themselves do not have a USB 2.0 interface, their card readers may.
Overall, it may work.
Dan Keaton
Augusta Georgia
Old November 22nd, 2010, 12:04 PM   #10
Sponsor: Convergent Design
CF Card Support
Hello
We have tested multiple lower performing Compact Flash Card's, And for use with our newly added Config Files, or for doing product updates. Transcends (133x or Higher 2GB,4GB,8GB) work just fine as well as San Disk Extreme 3, 4GB. and Lexar 4GB 300x. As for the Various CF Card's out there it is hard to say if we will for sure work. I would keep in mind the following.
Minimum Requirements:
133x or 15MB(s) Minimum
UDMA Support
233x or 300x May be More likely to work.
Also when trying a new CF card Format it in a PC FAT32 Before insertion.
Best Regards
Andy Mangrum, Tech Support Convergent Design, Inc
Andy Mangrum is offline   Reply With Quote
Old November 22nd, 2010, 12:27 PM   #11
Andy,
Thanks for the info. I wish that I could rename this thread to reflect your post. I think a lot of folks will want to have a cheap, small capacity card for config files. Your post goes a long way to helping me find a suitable card.
Again, thanks!
Jeff
Old November 22nd, 2010, 12:50 PM   #12
CF Card Support
Hello Jeff
No Problem, Glad I can be of Assistance
In the near future we will address this with various config file Configuration's For people to download,
Best Regards
Old November 22nd, 2010, 07:52 PM   #13
"Various Downloadable Config files"...
That would be simply awesome! and so very helpful to those either not setting up the nano / XDR every day or those using a multitude of the various configurations we've been given.
This is just a wonderful future feature!!!!
Thanks CD for doing the trial and error work for us.
