crackling audio - Page 2 at DVinfo.net
Convergent Design Odyssey
Old October 29th, 2010, 04:33 AM   #16
Dear Ian,
Thanks, it is good to know that you are running our 1.6.29 firmware.This is our latest production level firmware and it is use in thousands of nanoFlashes. This firmware came out in June and by now we expect that a majority of nanoFlash users are using this firmware,
We have a tool built into the nanoFlash which allows you to save all of your menu settings to a CompactFlash card.
Please format a CompactFlash card, first save any files that you want to keep that may be on the card.
Then, go to System|Create Settings.txt, then press the right arrow, then press Ok.
This will create a Settings.txt file, a file that lists all of your settings.
Please email that file to me at
CDSupport (at) Convergent-design (dot) com.
This will allow me to troubleshoot all of your nanoFlash settings and setup without the "interrogation" that Luben mentioned.
Without knowing how your nanoFlash is setup, it is difficult to troubleshoot the problem.
Dan Keaton
Augusta Georgia
Old October 29th, 2010, 05:55 AM   #17
Dan I have done what you asked and the settings are on the flash and i will send you the file
Ian
Ian Thomas.
Thomas Video Productions
Ian Thomas is offline   Reply With Quote
Old October 29th, 2010, 06:44 AM   #18
Dear Ian,
Thanks, I will be looking for it.
Dan Keaton
Augusta Georgia
Old October 29th, 2010, 09:19 AM   #19
Dear Ian,
I have your settings file.
Thank you for creating this file for us. This allows us to precisely check all of your settings for any issues.
Firmware=1.6.29
2010 10 28
12:41:59
/System/Max File Size: 100%
/System/File: File=Z1212001.MXF
/System/Trigger: Record button
/System/Duration: OFF,0
/System/Timecode/Source: Embedded
/System/Timecode/Dropframe: OFF
/System/Timecode/Seed: TOD OFF,00:00:00:00
/System/Source: SDI
/System/Prebuffer: OFF
/System/Power Saving/Auto Sleep: OFF
/System/Power Saving/Auto LCD Off: OFF
/Video/Bit Rate/CF HD Rate: QtMxf=140,Mpg=35,Working=140
/Video/Bit Rate/CF SD Rate: QtMxf=50,Mpg=9Working=50
/Video/CODEC: Long Gop
/Video/Record PSF>Prog: OFF
/Video/Play Prog>PSF: ON
/Video/Remove 3:2 Pulldown: OFF
/Video/720p 60/50>30/25: OFF
/Video/SD Aspect Ratio: 4:3
/Video/E to E Direct: OFF
/Video/T-Lapse: OFF,period=1
/Video/Crank: OFF,Base=24,Crank=24
/Video/HDMI Rx color: full range
/Video/35 Mb 1080 Width: 1920
/Video/Screen Tally: OFF
/Audio/In: Embedded
/Audio/Analog Settings/Mix In: Stereo Unbal
/Audio/Analog Settings/Preamp In: 0, 0
/Audio/Analog Settings/Gain In: 0,0
/Audio/Analog Settings/Gain Out: 3
/Audio/Record Channels: 2
/Audio/Monitor Channels: 1&2
/Loop Play: ON
/CuePlay: OFF,00:00:00:00
/Loop Record: OFF
I analyzed your settings and found no problems at all.
You posted:
"Thanks Dan
First the crackling appears on both my EX1+3 both audio from the cameras monitered vi headphones is ok
Just done a test with the EX3 and nano the audio recorded on the nano is slowmotion with some crackle
on the card in the camera is fine
The camera is recording at 1080 / 50i on the nano the audio is set to IN EMBEDDED REC CHANNELS 2 and MONITER CHANNELS 1+2 1080i 50 at 140mbs."
8. When you monitor the nanoFlash's headphone output, while recording, do you hear any crackling?
9. When you playback the recorded files in the nanoFlash, and monitor using the nanoFlash's headphone output, do you hear any crackling?
10. Are you reporting that you have problems with audio when playing back in an NLE?
11. If so, what NLE?
12. Is the video clear and free of any artifacts?
13. What CompactFlash card brand/type are you using?
Dan Keaton
Augusta Georgia
Old October 29th, 2010, 10:00 AM   #20
Hi Dan
Just played the nano vi hdmi to my hdtv and guess what it plays fine no sound distortion, my editor is a casablanca S2000 so it sounds like there is a problem there, the video is fine and the cards i use are Sandisk EXTREME 111 30mb/s and sandisk Extreme 60mb/s so after all this its the editer at fault
Many thanks Dan what a great backup and product
Ian
Ian Thomas.
Old October 29th, 2010, 11:47 AM   #21
Dear Ian,
I am very happy that this is now resolved and you can shoot using the nanoFlash with confidence.
Dan Keaton
Augusta Georgia
Old November 15th, 2010, 02:41 PM   #22
Sponsor: Convergent Design
Crackling Audio
Hello
Also It is good to keep in mind that USB cannot support playback of 180Mb(s)
We find here that anything over 50Mb(s) will at some point have crackly audio or will play "Jumpy"
If played using a USB CF Card Reader, Since it simply cannot handle the constant bandwidth,
Simply to verify if it is the reader, or the file, copy it to the desktop and play it in the same editor or viewer,
Best Regards
Andy Mangrum, Tech Support Convergent Design, Inc
Andy Mangrum is offline   Reply
